Spotted this on the bay
NTDWM
http://cgi.ebay.co.uk/VICKY-GREEN-LOOM-PINTO-AND-OTHER-7-CARS_W0QQitemZ170197044275QQihZ007QQcategoryZ100921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
oh no Jabbahutt cover your eyes
he'll get flash backs!
Hmm, am I missing something?
Too late Mr Whippy already suffering from flashbacks and daymares
too be honest though it was much more down to my lack of experience with electrickery than anytghing else. The more I work on it, the more I
can't understand why I had so much trouble.
Scrub the last bit, without the patience of fellow builders I'd be sat in the corner of my garage rocking backward and forward eating my crimping
pliers
Coozer
Basically in a nut sheel I have a Vicky Green loom and no electrical know how. to say the loom is unfriendly to use for a novice of the dark arts of
electrickery around the steering column is an understatement.
Originally posted by jabbahutt
Coozer
Basically in a nut sheel I have a Vicky Green loom and no electrical know how. to say the loom is unfriendly to use for a novice of the dark arts of electrickery around the steering column is an understatement.
Too late Mr Whippy already suffering from flashbacks and daymares![]()
too be honest though it was much more down to my lack of experience with electrickery than anytghing else. The more I work on it, the more I can't understand why I had so much trouble.
Scrub the last bit, without the patience of fellow builders I'd be sat in the corner of my garage rocking backward and forward eating my crimping pliers![]()
I have built two 7's with them and they have both worked well. Might not be simple but it is not really hard either and they are very good value for money.
i'm with steve here.
not bad value and reasonably easy.
it could do with a proper description of what all the pins on the column stalks do and also a schematic of the loom that is correct
there
are a few errors.
this electrical moron managed to get his car wired and working with the help of the guys here
and it's not a pile of smoking glass fibre yet
ditch
Whats all the fuss about? Use the wiring that came with the donor, all circuits set and no need to scratch you head over the column connections!
Dead easy
