Just bought this for breaking...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=320222208189
I want the engine (less inlet, sump, etc). Bumpers are sold. Anyone need anything else?
Cheers, Chris
can i have the inlet manifold, with injectors, fuel rail etc, and where the fuel lines connect to the fuel rail, can i have about 20 cm of both fuel
lines as they go in to the car? ( does that make sense? )
Ian.
Yes... probably! I wanted the fuel rail and lines/connectors, but I'm pretty sure I have spares of both so I can make up two sets.
I take it you want the nice press-fit connectors?
Chris
ok, well all im really interested in is the fuel lines that come from teh car that connect to the fuel rail lines. They end in a female squeeze tab
connector.
I want the female fuel connectors with about 10cm of plastic fuel line...
I then use these by sticking them into my rubber fuel lines so that i can use the standard connectors on the zetec manifold side fuel lines.
i have uploaded a picture to show what i want...
I know exactly what you mean. I'm sure I have a couple of spares of those, so no problem.
Should be picking it up on Saturday.
Chris
Thanks,
Where abouts in West London are you? Im in Tonbridge, so not too far ( i hope ).
mmmmmmmmmmmmmmmmm hubcaps,combine the airbag with bob,s dremmel and give it a great send off
Normally blow the air bags up, but a mate told me they fetch a tenner on eBay, so maybe I'll try that this time. I've not looked, so he may
well be talking bollocks.
Saigonij - the car will be in Denham, just off M25/M40 junction, so you can either pick up bits there or at my flat in Gerrards Cross, SL9.
Chris
can you stick them in the post to me?
how much for them?
Now have this car in my workshop ready for dismantling. Anyone else need bits off it?
Chris
Last chance for parts guys! I need the space in the workshop by the weekend, so it has to be stripped and gone by Friday as this is arriving....
http://www.locostbuilders.co.uk/viewthread.php?tid=85298
saigonij - so you want the whole manifold as you originally said, or just the fuel pipe connectors?
Chris
[Edited on 3/19/2008 by ChrisW]
