Hi all, this is the 2nd time i've posted this coz i put the put it in the wrong section! DOH.
My legerra has the door handles and boot lock fitted already but no frikkin keys with it.
doea anyone know what donor car the handles are from so i can track down a replacement?
Cheers.
I'm pretty sure they are off a morris marina, alternatively Lotus esprit
Yeap.. pretty sure standard ones are Morris Marina
MORRIS MARINA NEW BL DOOR HANDLE (RIGHT) | eBay
ouch.. I wouldn't be using that one !!
If they are Marina, they were also fitted to the Triumph TR7 - for its whole productin life
also think classic range rovers have the same handle
Range Rover classic right hand rear door handle O/S/R | eBay
God bless BL, they sure had their faults (a lotof em) but multi-model parts bin construction there is a good chice of cars to use to find bits, same
as Ford mechanicals.
cheers guys. xx
If they are the same as TR7 ones you can get just a new set of barrels for the locks from Rimmer Bros, just had a look £39 inc VAT. Could probably get a secondhand set of handles with keys from some where but a good last resort
Got the handles already fitted just need the lock barrels, thanks for the tip fella.
cheers. xx
