I'm about to wire up the fuel sender on my BEC, and predictably I've misplaced my copy of the MNR wiring loom destructions. Does anybody
know which of the following are for the fuel sender at the back of the car?
- Black, Green/Black
- Black/Yellow, Green/Orange
- Black/Grey, Green/Purple x3
One of these is a high level brake light, the other for the fuel sender and I can't think what else the other might be for as I've wired up
the fog, numberplate light, reversing light and driving lights.
James
If the loom is british standard colours, Green/Black is normally fuel sender.
Green Purple is brake light
However i'd check with some actual diagrams to confirm this.
[Edited on 23/3/14 by eddie99]
Green black on my 08 MNR
From the MNR instructions,
Off side branch
32 Black ring Ground to chassis
33 Green/black Fuel tank sender
Black Earth
We also recommend an additional earth from the filler cap directly to ground to prevent static sparks when filling.
34 O/S rear light cluster
Black Earth for lights
Red white O/S side lights
Green purple O/S stop lights
Green white O/S indicators
35 Red yellow Rear fog light
Black Earth
Superb chaps! Thanks all, this forum comes to my aid yet again
