any one running a supercharged engine on here,or have fitted one to an engine, if so what and how is it, thanks
just fitted rotrex supercharger on my dax rush hayabusa covered 1400 miles 250 bhp approx it runs very smooth tons of grunt
"bimbleuk" on here is using a toyota 4age with a rotrex supercharger fitted.
Mk sportscars ran a supercharged GSXR1000 demo car last year,rapid but not very reliable.
fitted spacer plate under barrel first regrind cams 440 injecters cosworth intercooler dynojet ignition module car has been great never missed a beat
always run a intercooler if you dont its a good chance it will go bang
on any forced air induction system you want to keep the air going into the engine as cool as possible! so its better to run an intercooler as air
under pressure is warmer the air not under pressure!
[Edited on 12/7/09 by omega0684]
on any forced air induction system you want to keep the air going into the engine as cool as possible! so its better to run an intercooler as air under pressure is warmer the air not under pressure!
what from warmer air entering the engine?
Sounds like a bonnet scoop would be a nice idea
im aware of this, but there are plenty of car that run f/i that run without them, they dont blow up,
When I bodged a supercharger onto my mx6 I had no intercooler, at only 6-7psi it was ok, any more and things would have started to melt, after a lot of flat out runs you could feel the heat in the pipes so even that low boost was probably asking for a meltdown :
im not sayin i wouldnt need an intercooler, i will run one, also engine will run on omex managment so fueling is taken care of
I've a factory supercharged V6 with no intercooler. Mine isn't running yet, but theres thousands of these engines out there running just
fine.
That being said, you would be silly to not put a intercooler in if possible. You gain a lot more power potential and do it safer.
For example, a car I helped build (383ci +15psi boost) used a centrifugal blower and 2 air/air intercoolers. It was able to lower the air charge
below the air intake temp which allowed for a LOT more power.
And Tom is correct. Any time you compress air you make heat and lots of it. You get about 15-18F increase of temp in the air charge for every 1psi
of boost added. Touch the head of your air compressor next time its running and see how hot it is.
I have been playing with superchargers since the mid 90s, all Toyota engines up till now.
I think your enquiry is too broad so you would be better off investing in a decent book such as "Superchared" by Corky Bell and do some
reading initially to get a good grounding.
I've built up a lot of practical experience as well as reading countless posts on forums, some useful, but mostly second hand info. So if I
started posting about my projects and experiences I could go on for days!
You mentioned using an OMEX ECU well they have a lot of experience with forced induction and specifically the Rotrex as they are a reseller. So
there's as good a reason as any to consider the Rotrex as a base. However the initial purchase price of the Rotrex puts a lot of people off.
Link to Supercharged
[Edited on 17-7-09 by bimbleuk]
I think your enquiry is too broad so you would be better off investing in a decent book such as "Superchared" by Corky Bell and do some reading initially to get a good grounding.
I've built up a lot of practical experience as well as reading countless posts on forums, some useful, but mostly second hand info. So if I started posting about my projects and experiences I could go on for days!
You mentioned using an OMEX ECU well they have a lot of experience with forced induction and specifically the Rotrex as they are a reseller. So there's as good a reason as any to consider the Rotrex as a base. However the initial purchase price of the Rotrex puts a lot of people off.
Hmm Rotrex + Duratec and you're using an OMEX well you have chosen a good combo because that's exactly what OMEX have been playing with for a while now. They were commissioned to produce a kit for one of the top manufacturers and have basically spent a year doing this.
thats handy.
This is exactly what i am building too.
My pistions and rods are on order so waiting for there arrival. Gotta start finding bits so i can think about dropping it in for the winter....Be
handy having someone else building one at the same time
just to change this a little bit, but what would be a better intake set-up??
Manifold witha single large TB on it running a map sensor most likely.
OR
ITB's with a plenum to pipe it up...but how wellw ould thi swork and what sort of metering would be used??
I know the Nissan Pulsar's run this set up, jst not sure how exactly.....
Originally posted by goaty
thats handy.
My pistions and rods are on order so waiting for there arrival. Gotta start finding bits so i can think about dropping it in for the winter....Be handy having someone else building one at the same time![]()
i am using Wossner forged low comp pistons and steel rods. going 1mm oversize too.
As for the cossy inlets, they seem quite expensive so i will prob modify or make something else fit.
OR
i have read this too, it involves running two maps etc so prob will make something else with single tb to make life easier.
cheers again
