having just put the engine back in the 7 after a while!!
the engine inards (waterways) seem quite flaky/rusty, what should i use to clear it before i put anti freeze in
Is there a rust descaler type of liquid i can use
i remember someone using vinegar to fill the engine, warmed it up and then flushed several times the engine with water before using antifreeze.
I am sure someone will back me up.
You can just flush it through with a hose, using a small wire brush to get at what you can reach.
