Zetec main bearing bolts
midge - 17/3/14 at 07:30 PM
Hi all,
Thoughts please, I'm swapping the 1999 Blacktop Zetec engine in my car and want to re-use the shortened sump I fitted. The sump has a oil baffle plate which is fixed to 4 main bearing bolts. They have each been drilled, tapped and fitted with a stud which holds the baffle in place. When I first fitted this they were a real pain to drill - can I reuse them in the new engine, a new series 3 zetec??
