Zetec inlet manifold
Monkeybasher - 6/3/08 at 07:17 PM
Hi,
I have just aquired a 2.0l zetec focus. I have this manifold lying about and have never used it, so am unsure how good it is. Will my otherwise standard focus benefit from this and a filter being fitted to it.
Any thoughts, as always are welcome
tim windmill - 6/3/08 at 07:29 PM
looks like my griffin manifold that i recentley purchased for my zetec supposed to be good for 150/160 bhp using standard fuel rail and throttle body
saigonij - 6/3/08 at 07:30 PM
the manifold has no provision for the ISCV, so you will have difficulty running the stock ECU on it.
I was going to go down that route with my kitcar, but, because of teh ISCV i woudl have to use a custom ECU, which put the expense up even more.
SeaBass - 6/3/08 at 07:32 PM
Where do the injectors go?
Monkeybasher - 6/3/08 at 07:46 PM
150/160bhp nice
No ISCV never thought of that, rubbish, may need to build another megasquirt
The injectors go just before the flange, the manifold is upside down.
Monkeybasher - 6/3/08 at 07:53 PM
Just thinking, I haven't even seen the zetec ISCV, but is it not possible to incorporate it with this manifold a wee bit plumbing and fabrication??
Monkeybasher - 6/3/08 at 08:36 PM
Just found this. Not sure what role it plays although its to do with the manifold, is it for Idle speed control??? Rescued attachment Photo-0124.jpg
saigonij - 6/3/08 at 08:49 PM
yea, that might be for the ISVC, although they are not normally 3 bolt holes though.... usually 2
Schrodinger - 6/3/08 at 09:08 PM
A while back I bought a similar manifold that came from a Ginnetta and it had a separate mounting "ring" for the valve which mounted between the manifold and the TB using the TB bolts.
It sits in my garage atm doing nothing.
tim windmill - 7/3/08 at 09:02 AM
mine is up and running without using the ISCV starts fine and ticks over nice snd smooth.
Schrodinger - 7/3/08 at 02:49 PM
I've found a picture but it's not up to much Rescued attachment throttle bod.JPG
saigonij - 7/3/08 at 05:33 PM
tim windmill, what ECU are you using?
MikeRJ - 7/3/08 at 06:16 PM
Originally posted by Monkeybasher
Hi,
Probably not. The very short runners on that manifold will undoubtedly hurt torque at low-mid RPM which is where you feel it the most on an everyday type car.
