Badger_McLetcher
| posted on 7/1/11 at 02:48 AM |
Ebay Plasma Cutter
COBEL 40A AIR PLASMA CUTTER / WELDER MACHINE on eBay (end time 09-Jan-11 21:24:09 GMT)
Looks a little too good and cheap to be proper... or am I just too cynical?
big_wasa
| posted on 7/1/11 at 07:59 AM |
same switch gear as mine. Its a cheapo. It does the job !
need4speed
| posted on 7/1/11 at 08:22 AM |
Just keep watching usually end up around £190, don't ask how I know I had some tool boxes from the same place a couple of years ago they were
a good buy, plus I can collect so saves me the postage.
Dave
Daddylonglegs
| posted on 7/1/11 at 09:34 AM |
Yep, £102 already! Probably the seller getting the bidding going like they always do
procomp
| posted on 7/1/11 at 11:46 AM |
Hi
If you are wanting to cut over 5mm thick material on a regular basis i would ask for a demonstration. Not seen that particular machine but when i was
looking at purchasing a plasma there was a lot of hype from manufacturers as to exactly what there machines where capable of.
Cheers Matt
blakep82
| posted on 7/1/11 at 11:51 AM |
i would just ask someone to cut the parts on a waterjet machine
________________________
| posted on 7/1/11 at 01:02 PM |
I have one exactly and its very good.
Thickest steel I'm tried is 6mm and it cuts through like butter.
interestedparty
| posted on 8/1/11 at 03:53 PM |
A friend of mine had one, got rid of it in the end because of the amount of air it used, a 2hp 50 ltr compressor couldn't keep up with it. Maybe
his was faulty (although it didn't seem to be)?
As some day it may happen that a victim must be found,
I've got a little list-- I've got a little list
Of society offenders who might well be underground,
And who never would be missed-- who never would be missed!
| posted on 8/1/11 at 07:21 PM |
no suprise there, it is a lot of air they use! Mine only lasts for a short time before a pause is required.
ISTR mine was about 400 from machine mart ive used it about 5 times in 5 years
