Author: Subject: Cheap engine donor..
posted on 27/10/11 at 11:56 AM Reply With Quote
Bang for bucks Lexus V8. Buy the car, get the engine and trans oput then get all your money back on the rest.
LEXUS LS400 4.0 V8 TAX AND TESTED NEW ALLOYS DRIVES SUPERB BARGAIN | eBay
owelly
posted on 27/10/11 at 12:03 PM Reply With Quote
Cracking engines but mating to a manual box could cost a bit!
http://www.ppcmag.co.uk
Confused but excited.
posted on 27/10/11 at 12:45 PM Reply With Quote
I seem to recall someone on here doing just that and fitting a twin turbo set-up.
l0rd
posted on 27/10/11 at 12:52 PM Reply With Quote
Quickly delete the thread before Scoutz reads it
Badger_McLetcher
posted on 27/10/11 at 12:55 PM Reply With Quote
As above, the engine is awesome. However getting a manual box to mate up is a PITA.
You need:
- Custom adapter plate/bell housing to fit your choice of box
- Custom flywheel since there are no known flywheels that just bolt on. You can slot an MR2 item, but that's generally considered dangerous.
- Clutch with throwout bearing (or you may get away with using the one that goes with the 'box).
However get the right engine and you can get it up to about 500bhp without having to crack open the engine, 1000bhp with a set of new pistons apparently (all FI of course). They don't tend to breathe very well for NA.
That car is on the borderline I think, after '95 they reduced the size of the conrods so those would also need replacing.
This is all from memory, so may vary in accuracy lol
If disfunction is a function, then I must be some kind of genius.
