Mark Allanson
posted on 2/1/09 at 11:10 AM |
What are the chances of this being OK?
My sister needs to upgrade from 2KPro to XP, would this be a good idea - seems very cheap to
methis
posted on 2/1/09 at 11:14 AM |
Only problem will be that it's a Dell CD and some OEM versions of XP were restricted so they'd only work on computers with that
motherboard. If you put it on a non-Dell PC it might not like it when you try and activate it..... Of course if it's a Dell PC it's no
problem!!!
RichardK
posted on 2/1/09 at 11:23 AM |
most are bios locked so won't work unless yours happens to be the same dell pc and model!
Rich
Gallery updated 11/01/2011
Ben_Copeland
posted on 2/1/09 at 11:47 AM |
Tried using my Dell Xp cd from my laptop on my new computer.... didnt work.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
stevebubs
posted on 2/1/09 at 12:26 PM |
Dell XP CD worked fine on one of my PCs...
wilkingj
posted on 2/1/09 at 01:35 PM |
The BIG Issue, is will they give you a product key with it?
Without it its a very very expensive and useless CD.
The CD's are worthless, its the Key code that unlocks the installation thats the bit you want to pay for, or make sure you get one with the
CD.
Also some Manufacturer specific CD's have a different number sequence and wont install without the matching key code.
Some will also depend on which version of the disc you have.
ie make sure you get the right code for the right disc.
Also you can only install using your code 3 times, then you have to phone up Microsoft to get it fixed. This is reasonable and deters people from
installing many times on different PC's.
The Ad says its got the COA, however that booklet and bar code shown is NOT the COA. We have hundreds of those booklets he shows in the drawer at
work, NONE of them have the COA sticker in with the booklet. (It came stuck to our machines)
Hope this is useful.
Happy new year.
Best Regards
Geoff
http://www.v8viento.co.uk
stevebubs
posted on 2/1/09 at 02:39 PM |
CD.
Happy new year.
Agreed. The COA is key. You can download the CD via torrent. My COA came loose as a loose unused sticker on a sheet ready to be attached to a machine.
prawnabie
posted on 2/1/09 at 04:33 PM |
Most of the DELL OEM windows cd's I have used don't need activating, even the xp / vista ones.
Shaun
