Author: Subject: Like a bike engine... with torque
andrews_45
posted on 16/1/07 at 07:06 PM Reply With Quote
Looks a bargain to me, anybody fitted one of these?
http://cgi.ebay.co.uk/MAZDA-RX8-ENGINE_W0QQitemZ150081831629QQihZ005QQcategoryZ52640QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
locoboy
posted on 16/1/07 at 07:24 PM Reply With Quote
Spins the wrong way IIRC
Locoboy
Project7
posted on 16/1/07 at 07:50 PM Reply With Quote
Why couldn't you use the RX8 gearbox and diff? - Wouldnt matter what way it spins.
http://cgi.ebay.co.uk/ MAZDA-RX8-GEARBOX_W0QQitemZ150081495141QQihZ005QQcategoryZ52640QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
cloudy
posted on 16/1/07 at 08:05 PM Reply With Quote
or you could flip the diff in the casing?
James
iiyama
posted on 16/1/07 at 08:09 PM Reply With Quote
Much heavier then a bike engine.......And not as good as the 13b......
If its broke, fix it. If it aint broke, take it apart and find out how it works!
jlparsons
posted on 16/1/07 at 08:14 PM Reply With Quote
Not as good as the 13b? I thought it was the same engine further developed? Same power and torque without turbo?
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
Volvorsport
posted on 16/1/07 at 08:57 PM Reply With Quote
my mate built a westfield with a rotary engine and box , using a sierra diff .
www.dbsmotorsport.co.uk
getting dirty under a bus
novacaine
posted on 16/1/07 at 09:13 PM Reply With Quote
apprently the RX8 engine is better than the RX7 in terms of reliability, i.e not having to replace the rotor every 30,00 miles to retain performance and economy
the RX8 engine is very good, i know someone that drives one, smooth and powerful but crap fuel effeciency but in a 7 who cares? but i think they sound crap IMHO just a bit too "whirry" instead of the sweet noise of a V8
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
marksimon
posted on 16/1/07 at 09:14 PM Reply With Quote
In my opinion the RX8 engine is a seriously good proposition for lightweight front-engined rear-drive cars.
Where else can you get 230 hp in a small and light package for less than 1K ?
My thoughts:' this engine gives R500 equalling performance ( albeit about 10 kg heavier as an installed package ) with potential for 100+k mile durabilty all for less than 1K. Compare the power with that for the R500 when the gearing is modified to suit. The RX8 is way better.
Other benefits:
Silky smooth, 9.5k rev limit, 1300cc = low insurance and road tax.
I believe that you can get aluminium housings to get the weight lower than a k-series! Not sure about the costs.
Downsides:
> Image ( do I care ? yeah because I'd like a Cosworth BDG)
> Fuel consumption
> Relative to normal engines, requires a larger silencer and a well insulated exhaust manifold
> ECUs to run rotary engines are less commonly available compared with normal piston engines
> No one else uses one so I'd be on my own with regards to installation, engine mounts, manifold etc
If I were in the market I'd definitely use one of these engines.
P.S. Am I wide of the mark ?
posted on 16/1/07 at 10:15 PM Reply With Quote
Goes the wrong way? Put it in the back and drive the front wheels...
[Edited on 16/1/07 by coozer]
russbost
posted on 16/1/07 at 10:28 PM Reply With Quote
I've heard of people using the RX7 lump in 7 type cars & they go like Sh*t off a stick. The Rx8 is even better & who cares if they chew rotors in 30,000 miles who ever does 30,000 miles in this type of car!!!
DIY Si
posted on 16/1/07 at 11:57 PM Reply With Quote
Is that the 3 rotor one? I believe some of the hassle could be removed by using carbs. IIRC one of the UK tuners use SU carbs as one of the first upgrades! Or go silly and use the direct port stuff, simply big, straight tubes that lead to the block with a carb on the end!
Sun Tzu, The Art of War
iiyama
posted on 17/1/07 at 11:41 AM Reply With Quote
Totally different engine!
iiyama
posted on 17/1/07 at 11:42 AM Reply With Quote
30,000 is a myth. Should get at least 60k out of a looked after engine
iiyama
posted on 17/1/07 at 11:45 AM Reply With Quote
The 3 rotor is not a standard engine in either the 7 or the 8. and a 3 rotor would rip a locost chassis tho shreds!! In fact I would suggest that a 7 type car would struggle with a tuned 13b. On stock twins you get around 250bhp as standard although cant remember the torque figures. However these engines can be tuned to a reliable 360-400bhp on twins and if a single is fitted, like a T51, then 600bhp is easily achievable
Memphis Twin
posted on 18/1/07 at 12:34 AM Reply With Quote
Spins the same way as a Ford, which is the "right" way.
jlparsons
posted on 18/1/07 at 06:07 PM Reply With Quote
Looks like a good compromise to my mind. I like the bike engine idea but I want to use my car everyday and the reliability issue would catch up to me quick, plus itd be tiring all the time. On the other hand, car engines are heavy and you need to do some serious monkeying about and a lot of spending to get a power-to-weight that would match a bike engined car.
This is far lighter than a 2 litre lump, has 230 horses straight out the box and revs to 9k. Perfect. Each to their own though. Bike engine would still be it if I was building a sunday car or track day special.
The big problem is I'm not sure what electrical gubbins are required to get it moving outside the rx-8. For that reason a 90s BMW 6 or a duratec 4 is probably what I'm aiming for.
Anyone know how to wire up an RX-8 engine then?
iiyama
posted on 18/1/07 at 06:19 PM Reply With Quote
RX-8 ECU's are a nightmare!
jlparsons
posted on 18/1/07 at 10:08 PM Reply With Quote
That's what I thunk. Shame. Still, someone's got to be first. Perhaps I can sweet-talk a mazda service engineer. £3k for a duratec with equivalent power in far-from-waranteed spec, or a grand for an stock RX-8 engine and end up spending the rest on making it start in a locost.
I think the only way to do it would be to buy a written-off RX-8 with good running gear and take note of everything as you dismantle it. Sell all the other bits on ebay and might make up the cost too.
Anyone giving it serious thought? Or started one?
jlparsons
posted on 18/1/07 at 10:17 PM Reply With Quote
13B-MSP RENESIS
Mazda RENESIS prototype in the Mazda MuseumThe RENESIS is an evolution of the 13B and first appeared (in production) in the 2002 Mazda RX-8. It is available in two versions : the standard-power version (222 Nm @ 5000 rpm and 192 hp @ 7200 rpm) and the high-power version (222 Nm @ 5500 rpm and 232 hp @ 8500 rpm). Compare this to the Mazda RX-7's twin turbocharged 13B-REW's 255 hp (190 kW).
wikipedia
stevebubs
posted on 18/1/07 at 10:30 PM Reply With Quote
OK....wrt electronics....
Bill Shurvinton has been tinkering with getting a Rotary to work with MS for quite a while now, so if you were considering this route then he would be my first port of call...
jlparsons
posted on 18/1/07 at 11:41 PM Reply With Quote
Is that the one from the rx-7 or the rx-8? I've seen locosts built with rx-7 engines, look damn good too. I saw one guy who built his chassis 'book' size then was able to shrink it further once he'd fit the engine as he had excess space.
Never seen a locost with the rx-8 engine, though I did search a bit when I was thinking about it for my build. I concluded in the end that it needed someone with more experience than me to be the trailblazer. I've got at least another 6 months of planning though (baby) before I start looking for donors, so who knows.
procomp
posted on 19/1/07 at 08:34 AM Reply With Quote
Hi there was also a discussion on the wscc site similar to this one also with input from Bill. WSCC linky
cheers matt
jlparsons
posted on 19/1/07 at 06:42 PM Reply With Quote
useful, thanks mate.
Doubt I'll have the guts though to be honest, unless I can assure myself that I can definitly get a renesis running. Perhaps speaking to a couple if the tuners on that link might do that, but even so a duratec 2.0 is such a tried and tested (and powerful) solution it's hard to pass up.
