gy351100
posted on 16/4/07 at 06:43 PM |
cortina caliper seals
hi all
where can i get a set of cortina caliper seals or recon calipers for less than £35
(£75 per pair)
cheers
TGR-ECOSSE
posted on 16/4/07 at 06:51 PM |
Out of interest i called a local motor factor and they had them in stock at £35 each so will be a bit cheaper with trade discount if you can get it so
its worth calling around
Myke 2463
posted on 16/4/07 at 07:16 PM |
Hi.
Seal kits are available from motor factors about £ 6 - 8 for a complete set. Very easy to fit. Be Lucky
mackei23b
posted on 16/4/07 at 08:47 PM |
try
http://www.biggred.co.uk/
Ian
gy351100
posted on 16/4/07 at 09:30 PM |
hi again
local motor factor can't supply only seals will only supply callipers
looks like big red is the best bet
cheers for your help
