orbital
posted on 16/11/08 at 04:17 PM |
Wiriing Indicator Switch
Lo All,
Right I'm sat in me garage with my latptop hoping that one of you lovely people can help me out. I've removed my Sierra steering column
switches and I'm just about to wire up the indicator on/off/on switch I've bought. the only problem being I'm quite retarded in the
electrics department and I'm not sure what wire goes where. From the Steering column plug I have the following:
Switched +VE Supply (black)
RH Indicators (black/green)
Permanent +VE (red)
Flasher relay (black/red)
LH Indicators (black/white)
Flasher relay (black/white)
Then on my on/off/on switch I have three terminal numbered 1 to 3 (it's a PWS switch if that helps). So as I said earlier, err what goes where?
becasue I haven't got the foggiest If I'm honest!!
Dave
big_wasa
posted on 16/11/08 at 04:27 PM |
pic is how the sierra is done.
[Edited on 16/11/08 by big_wasa]
orbital
posted on 16/11/08 at 04:37 PM |
Cheers for that mate,
So looking at the diagram I'd have LH indicator to left terminal on the switch and RH indicator to right terminal on the switch and the flasher
realy to the middle terminal? Sounds far too simple to me! But I'll have a dabble and see what happens. Hopefully nothing loom melting I
hope!
Dave
orbital
posted on 16/11/08 at 05:38 PM |
Hmm that didn't work
Any ideas what I'm doing wrong?
Dave
omega 24 v6
posted on 16/11/08 at 06:02 PM |
Hmm that didn't work Any ideas what I'm doing wrong?
Mmm sounds like it should have worked. On your switch there are three terminals yes?? It has three toggle positions yes??
If so the one of the terminals on the switch should be common to the other two depending on where the switch is at.
You could try touching the terminals together to see if the lights work just to be sure your problem does not lie elsewhere
ETA your flasher unit is connected isn't it and earthed??
[Edited on 16/11/08 by omega 24 v6]
orbital
posted on 16/11/08 at 06:53 PM |
Yes mate the switch has three positions (off being in the centre) and three terminals.
At the moment I still have the original Sierra switch gear attached. All I've done is removed the LH indicator wire, the RH indicator wire and
the black/red flasher relay wire from the connector and attached them to switch as I said above. but nothing happens when I throw the switch either
way. Should I have the other flasher wire connected to comething? the black/white one?
If I put the wires back into the orginal seirra connector evrything works fine and I can hear the relay switching fine.
Thanks for your help
Dave
[Edited on 11/16/2008 by orbital]
orbital
posted on 16/11/08 at 07:46 PM |
Wahooo!! I've sussed it
I'd taken the wrong flasher wire. I'd used the black/red wire first (49) and it seems I should have used the other black/white one (49A).
Looking at the Haynes manual gave me a clue as the the column switch (item 61 in the manual) seems to have some sort of switching internally for the
hazard switch. This makes me worry slightly as I have a Savage hazard switch to replace the column one and that looks even more confusing!!!!
Dave
omega 24 v6
posted on 16/11/08 at 07:48 PM |
OK the black red wire comes from the hazard switch. It is powered either by the ign or a battery voltage depending on the position of the hazard
switch.
So you will need the hazard switch connected and the ign on to make it work also to make it fash you will need to reconnect the red/black to the
flasher unit and connect the black/white from the flasher unit to the common terminal of the switch. Have you got autocad on your machine or a
facility to look at dxf files?? I could send you a line diagram I have here.
ETA well done
orbital
posted on 16/11/08 at 08:13 PM |
I think I've got a viewer for DXF files knocking around mate, so by all means send away!! (and thanks a lot skipper!)
Dave
