Author: Subject: part built on the bay of e, not long left
tomgregory2000
posted on 26/1/09 at 10:25 PM Reply With Quote
NTDWM click ne
[Edited on 26/1/09 by tomgregory2000]
cloudy
posted on 26/1/09 at 10:59 PM Reply With Quote
That is shockingly badly built! I particulary like the brake lines cable tied to the rear axle!
James
www.warnercars.com
omega0684
posted on 26/1/09 at 11:13 PM Reply With Quote
i think cloudy has a stutter! but have to agree it does look very poor!
Lars
posted on 26/1/09 at 11:29 PM Reply With Quote
Nothing wrong with cable tying brakelines to the axle, should have used some rubber around it though.
Mine passed SVA like that, even though my t piece was solidly bolted to the axle.
cloudy
posted on 27/1/09 at 12:11 AM Reply With Quote
A stutter?
Personally I would not want my brake lines being pressed against steel in a high vibration area!
James
www.warnercars.com
posted on 27/1/09 at 08:48 AM Reply With Quote
My brake pipes are just in the original Ford clips which only hold them in place lightly, how does a back axle vibrate?
[Edited on 27/1/09 by Peteff]
Mr Whippy
posted on 27/1/09 at 09:04 AM Reply With Quote
I used landys offroad for years with all the pipes held on with tie wraps, never failed the MOT or came off, just looks horrible. I think its safe to say though looking at the rest of the car that it is quite likely, not finished and there’s no point in jumping to conclusions about a part built car…
Looks a reasonable job so far, worth the money and would save someone quite a bit of time.
wilkingj
posted on 27/1/09 at 10:20 AM Reply With Quote
On my Landy the brake pipes are wrapped in a piece of bycycle inner tube (only where they could rub) and held with ti-wraps.
The inner tube stops the rubbing and the ti-wrap holds it in place.
Some were like that for 13 years.
Its more about stopping them from rubbing against anything. After all waht does those special plastic U clips do? They hold the pipe in place and stop it from rubbing against anything.
Strapping a brake pipe down to bare metal is a no-no in my book. Thats asking for long term trouble.
EDIT:
I seem to recall that the Ford clips on the axle had a split rubber bush / tube /grommet through which the brake pipe passed to stop it rubbing on the axle and the clip. A bit like my locost Bike inner tube job.
[Edited on 27/1/2009 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
greggors84
posted on 29/1/09 at 02:49 PM Reply With Quote
Not sure about the racing stripe down the rear panel!
Chris
The Magnificent 7!
posted on 29/1/09 at 03:56 PM Reply With Quote
[quote=wilkingj]EDIT:
Mine didn't, they were straight into the clip just like the original W reg Ford Capri ones they came off which had never failed
