flak monkey
| posted on 11/2/09 at 08:48 PM |
Bargain duratec v6 (st)
Spotted on ebay..
http://cgi.ebay.co.uk/ford-mondeo-st24-full-engine_W0QQitemZ330306620029QQ
Bargain if you want one....
Sera
http://www.motosera.com
cd.thomson
| posted on 11/2/09 at 10:19 PM |
do people actually fit these v6s?
Craig
Chippy
| posted on 11/2/09 at 11:43 PM |
  Engine
Well some of us do,
 Cheers Ray
MikeR
| posted on 12/2/09 at 12:09 AM |
I guess not.
Looks like hte engine is offset to the drivers side. Is that right? What gearbox have you used?
| posted on 12/2/09 at 12:47 AM |
quote: Originally posted by Chippy
Well some of us do,
 Cheers Ray
That's a Cosworth V6 from Granada/Scorpio isn't it?
The Duratec is a bit limited in the range of manual gearboxes that mate up to it. The Jag S-Type is the only one I know of, and even that's not
a completely simple bolt on as the 3.0L Jag engine has a few differences.
carpmart
| posted on 12/2/09 at 08:54 AM |
As per MikeRJ's post limited on gearbox mating which is what makes the engine relatively so cheap!!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
alfasudsprint
| posted on 12/2/09 at 12:45 PM |
The Nobles used the ford V6, albeit turbocharged, dunno what box they used?
grazzledazzle
| posted on 12/2/09 at 12:52 PM |
I've got an st200 fitted to a cosworth T5.
I would not buy one with 80k on it though, cars with that kind of mileage that haven't had the chocolate ford water pump changed will not be far
off going bang. The St24 motors are ten a penny at that price, a friend just paid £225 for a 22k mile engine.
Noble fit it mid-engine and therefore don't use a RWD box. Morgan fit them now using a T5 and have a bellhousing available to do it. Mine uses
an adaptor plate with standard cosworth t5 bellhousing and works fine.
[Edited on 12/2/09 by grazzledazzle]
Chippy
| posted on 12/2/09 at 10:54 PM |
No if anything it's just slightly to the passenger side. Gearbox is an MT75 which is a bit stronger than the Type 9.
Yes BOA Cossy now putting out around 230 bhp, but needs to go on the R/R for a tune up, (once I get the car back together) Cheers Ray
greggors84
| posted on 15/2/09 at 06:13 PM |
The Mondeo V6 uses a MTX75 gearbox, which is same as the zetec (im pretty sure). You would thing they would have a similar enough bolt pattern to use
the same bellhousing for a zetec to type 9.
Apparently its not so though!
Chris
The Magnificent 7!
| posted on 16/2/09 at 09:30 AM |
The MTX75 designed for the Duratec has a different bellhousing to the Zetec box.
