cd.thomson
posted on 13/10/09 at 10:13 AM |
BE - soldering kit
Hi guys, looking at maplins an iron + desolder pump + solder is around £20+
this looks attractive and comes with a 1 year guarantee..
>>LINKYPOOS<<
Craig
thefreak
posted on 13/10/09 at 10:23 AM |
>>LINKYPOOS<<
The Maplins one (if they're the yellow handled ones) are very good and dont heat up the handle while you're using it and burn your hands.
the cheaper versions tend to, and the solder is rubbish, spits everywhere and doesn't make a good joint.
I'd rather pay a bit more for a decent iron and solder than a cheap kit myself. Used to hate using the crappy one at work so much I used to
bring my own in if I needed to do anything and put the job off for a day
cd.thomson
posted on 13/10/09 at 10:40 AM |
tbh anything is better than the 40w spade iron and plumbers gas solder that we currently have in the garage!
Craig
thefreak
posted on 13/10/09 at 11:10 AM |
I bought a 15w and went back for a 25w one because I liked the 15w that much.
miikae
posted on 13/10/09 at 12:27 PM |
A Weller TCP is the one the Pro's use, interchangable bits of various sizes and heat ranges, i have 3 of them one with a de-soldering attachment
, i've had them for years.
They do come up on ebay from time to time.
Mike
[Edited on 13-10-2009 by miikae]
If it can be done it i will be done .
iceman26
posted on 13/10/09 at 01:45 PM |
Aldi had gas 1s for about 14 kart week and are very good
COREdevelopments
posted on 13/10/09 at 06:48 PM |
i have got an aldi special one, and it is bloody brilliant. i use it to fix plastics too. so good i bought 2. 1 for home and 1 for work.
Rob
Confused but excited.
Mike
What he said. I've had mine (TCP 2) for over 15 years and still on the original tip.
Best iron in the world. Tiny iron but temperature controlled tip. Delivers 45W as required.
I have soldered four ends of 2.5 solid together, no problem.
