Author: Subject: redtop batteries,will i have got away with it?
StrikerChris
posted on 17/1/10 at 02:31 PM Reply With Quote
how do redtop batteries cope with recharging?just went to start my car,after well,probably xmas time and its flat!will run the pump but not kick it over.whats the chances it'll jump back into life or is it likely goosed now?
loggyboy
posted on 17/1/10 at 02:42 PM Reply With Quote
acording to the optima site ( I ssume its an optima redtop?)
  • Less deterioration due to deep discharge than conventional batteries
  • More "cycles" before aging than conventional batteries
  • Faster charging is possible compared with conventional batteries!
So it would seem you should have no problems
[Edited on 17/1/10 by loggyboy]
StrikerChris
posted on 17/1/10 at 03:02 PM Reply With Quote
that sounds hopefull cheers!cant afford another this time of year!
GMPMotorsport
posted on 17/1/10 at 04:04 PM Reply With Quote
I have had to charge my one up for the first time this winter, seems alright now though.
www.gmpdevelopments.co.uk
www.gmpmotorsport.co.uk
ARDS Instructer.
twinturbo
posted on 17/1/10 at 04:57 PM Reply With Quote
They get recharged every time you run the car. So long as it's not actualy died then it should charge fine.
TT
Bluemoon
posted on 17/1/10 at 04:58 PM Reply With Quote
Put it onto charge, don't jump start it.. You'll find out if you have got away with it soon enough! In principle if it's not got bellow 10.5V you stand a good chance of success..
Dan
beaver34
posted on 17/1/10 at 05:09 PM Reply With Quote
how about if its below 10v, any way of reviving them?
ashg
posted on 17/1/10 at 05:47 PM Reply With Quote
be careful recharging these gel batteries they are meant to be charged with a special charger not a normal car battery charger.
you can do it with a normal charger but i would suggest using no more than 1amp and keeping an eye on it all the time.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Bluemoon
posted on 20/1/10 at 10:53 AM Reply With Quote
Not sure if you succeed or not? Some charges (C-TEC) have a de-sulphation mode that is supposed to be able to bring back heavly discharged batteries.
posted on 21/1/10 at 05:31 AM Reply With Quote
The Odyssey/Varely batteries aren't gel types. They can be safely charged with normal battery chargers according to the manufacturers, though I wouldn't be using a very high current charger on the smaller batteries.
