Author: Subject: Low lift jack what are your thoughts
Danozeman
posted on 24/2/10 at 01:02 PM Reply With Quote
What do you all think the quality of this will be like?
40 quid for a low trolley jack.
linky
Dan
mookaloid
posted on 24/2/10 at 01:11 PM Reply With Quote
If I was looking for a low jack - I'd probably give that a go
Ben_Copeland
posted on 24/2/10 at 01:22 PM Reply With Quote
My first thoughts are it's too cheap for a good quality jack, plus sockets, LEDs etc etc. I'd expect it to break easily.
Ben
Locost Map on Google Maps
Enter Your Details Here
MikeR
posted on 24/2/10 at 01:28 PM Reply With Quote
40 quid is far more than i paid for my halfords jack a few years ago. It seems to high the plus points we all want - although i'd only ever lift a seven on it - wouldn't like to test out the full weight capacity.
Does the german TUV give us any confidence or is it like ISO 9000 - aka "we do what we say, so pray we don't say we're cr&p"
Johneturbo
posted on 24/2/10 at 02:29 PM Reply With Quote
Has anyone ever thought about making a paddock stand type jack, that you just fit under the chassis and push down to lift up
i can't fit anything under mine without taking the nose off
Humbug
posted on 24/2/10 at 02:38 PM Reply With Quote
To lift the front of my car high, I have to use a small tintop scissor jack first to get it high enough for the trolley jack
Alternatively I do have a pair of ramps and wheel chocks
[Edited on 24.02.2010 by Humbug]
posted on 24/2/10 at 02:49 PM Reply With Quote
I use a piece of 4x4 timber and a brick...
posted on 24/2/10 at 03:00 PM Reply With Quote
wot's the price of a MMart equivalent?
what are the odds of the LEDs being crush by the fouth time you have used it?
biu it, assume it will fial by using axle stands, wooden blocks etc until you can trush it.
obviouls, as with any jack, regardless of price or quality, you never stick your neck out without some additional support.
franky
posted on 24/2/10 at 03:29 PM Reply With Quote
Looks good for the cash, TUV testing is done to a higher standard than over here.
its not like you're lifting that much weight with it either.
Go buy
wilkingj
posted on 24/2/10 at 03:30 PM Reply With Quote
Being a Bat F'stard.... I use a SMALL set of ramps. They are home made and work fairly well. I can then access most parts of the car I need to.
The Viento Fits!
The Viento Fits!
Best Regards
Geoff
http://www.v8viento.co.uk
flibble
posted on 24/2/10 at 03:57 PM Reply With Quote
Blimey ^^ They look pretty terrifying to drive up!! Damn good idea though
hobbsy
posted on 24/2/10 at 03:59 PM Reply With Quote
^^^ Crikey - I'd hate to see a set of ramps you class as LARGE then!!!
Krismc
posted on 24/2/10 at 06:12 PM Reply With Quote
Them jacks look like the ones at costco and are very very heavy
posted on 24/2/10 at 07:02 PM Reply With Quote
The LEDs looks like a gimmick that won't last long, but I like the idea as it can be difficult to see under cars when positioning jacks.
I also like the fact you can clip the handle to the jack; mine often seem to get parted from their jacks somehow and I end up using a breaker bar or similar to jack the car up!
13kg, certainly not light, but I'd rather a cheap heavy steel jack than those nasty alloy abortions that cost double this.
[Edited on 24/2/10 by MikeRJ]
Steve Hignett
posted on 24/2/10 at 08:23 PM Reply With Quote
Yes, I've made one of those paddock stands. I use it all the time!
I'm going to make another one in the next few weeks! (not that I need two, I just fancy making a really lightweight one!)
stevegough
posted on 24/2/10 at 10:12 PM Reply With Quote
What about one of these to get it up - then bung in the axle stands!
One drawback is that the car need to be running....air jack
[Edited on 24/2/10 by stevegough]Image deleted by owner
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
T66
posted on 25/2/10 at 10:45 AM Reply With Quote
Ive just bought this 3000kg jack from Costco
£60....
To jack my saab up without first using the Saab scissor jack will be heaven
http://www.detailingworld.com/forum/showthread.php?t=129861
posted on 25/2/10 at 10:54 AM Reply With Quote
That's why they put wheels on them The leds look a bit of a gimmick but if it works it's well worth the money.
Danozeman
posted on 25/2/10 at 03:47 PM Reply With Quote
That costco one looks the virtually the same. Theres no costco near me though
I need a low one as my car is now too low for my trolley jack.
May give the ebay one a chance. Just have to measure im not sure 80mm is low enough.
Dan
