eddie99
posted on 26/4/10 at 11:51 AM |
1.6 shawspeed zetec
Stolen of the puma forum:
http://www.pumapeople.com/forum/index.php?showtopic=99953
If you can't see it:
First Off People im new to pumapeople im off ZSOC and own a Fiesta MK5 ZS. But i feel this engine is good to you puma owners so here is goes! Need to
fund my new engine buld! I will either sell engine as it is or split for parts or just the cam set up heres some info:
Engine
Phase 2 Blacktop Zetec SE Engine on 38K (Clocks to prove) and service history
Engine looks brand new on apperance alone. It was driven 33K by a 55 Yr old woman and 5K by me.
Engine has full service history all done from Ford, With one done only 1K ago
Set up
Shawspeed SS4 Cams - Fitted by JRS Motorsport
HD Big End Bolts - Fitted by JRS Motorsport
Dreamscience Custom Mapped ECU (With Launch Contol & Rev Limit of 7150RPm) - Around 145-155 Bhp (Two People on ZSOC have same set up one RR at 153
other at 147, which is the best figures so far on SS4's) - With the ECU you also get one more map for free if you do any other mods
New Uprated Shells fitted before bolts were changed
All this done at Christmas
Engine is very fun and revvy to drive!
Prices
First off ill tell you how much it has cost me and how much i will sell
Engine as it is with Cams Fitted & Mapped
38K Phase 2 Engine Possibly worth - £600-700
SS4 Cams & Bolts - £400
Uprated Shells - £120
ECU With Dreamscience Custom Map - £450
Fitting was £350 For Cams,Bolts And Shells. So thats £2000 worth of kit.
Will sell for £1300 o.n.o or £1600 Fitted with New Fluids and everything needed to put into a puma
Shawspeed SS4 Set Up Kit
Thats £850 worth of kit. Plus another map by Dreamscience for free. Maybee need tweaking if put in different engine.
£700 o.n.o
Engine Completley Standard
On 38K Running Engine £600 o.n.o
If your only after certain bits, PM me. Offers on everything something can always be sorted
Will fit a puma easily, i can supply RH Engine mount that would be needed when putting this into a 1.7 puma (not sure about 1.6 or 1.4) and i can also
supply wiring for either anologue or digi dash. This can be easily dropped into a puma and would be something different in a puma!
Phone number - 07859903370 if it would be easier.
I MAY BE INTERESTED IN P/X WITH SOME ITEMS LET ME KNOW!
Reason Sump is off guys is i rounded out the oil drain plug and had to get the oil out before transporting the engine back home form mates garage in
my mums new audi! Will be put back on for th enew buyer!
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
MakeEverything
posted on 26/4/10 at 12:35 PM |
Sounds expensive to me for an engine with limited modification and power that can be had for less money with a different engine. IMO of course.
Kindest Regards,
Richard.
ashg
posted on 26/4/10 at 03:52 PM |
its the age old thing of there is no replacement for displacement. if you hunt around you can get a 2.0 duratec for that kind of money.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
eddie99
posted on 26/4/10 at 03:54 PM |
Oh ok i thought that looked reasonable, thought the 1.6's were worth quite a bit. Oh well
