<<  1    2  >>
Author: Subject: I think I've bought my first duffer...
posted on 26/7/10 at 06:20 PM Reply With Quote
Rover V8, well chuffed... until.... turn the crank and goes round, click, pertang, jammed.
Back about 270 degrees, jammed, back the other way, click, pertang jammed.
AARRRRRRRRRRRRRRGGGGGGGGGGGGGGGGHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!
Any ideas?
[Edited on 26/7/10 by coozer]
clairetoo
posted on 26/7/10 at 06:21 PM Reply With Quote
Stuck valve ? ( )
Its cuz I is blond , innit
Claire xx
Will weld for food......
Sounds like it's broken
Killer
posted on 26/7/10 at 06:25 PM Reply With Quote
Bent valve would be my guess mate
R
lotusmadandy
posted on 26/7/10 at 06:28 PM Reply With Quote
Maybe a couple of broken teeth on the timing gears.
I seem to remember rover v8's having an issue with this.RPI do a kit to replace the gears.
MakeEverything
posted on 26/7/10 at 06:32 PM Reply With Quote
Check the flywheel isnt obstructed.
When i turned over the cosworth i felt a knock, knock, knock clunk as i turned it, and i thought the worst, until i realised that i hadnt tightened the flywheel bolts!!
Kindest Regards,
Richard.
RichardK
posted on 26/7/10 at 06:39 PM Reply With Quote
Sounds a bit ominous mate, have a check somebody just hasn't chucked any old spark plug in there to keep the bores dry.
Compression test maybe a starter for 10 for a knackered valve, not right so I'd be tearing it down by now but I think you're more sensible than I so will be waiting for all the intelligent answers!
Hope its nothing mate...
Rich
Gallery updated 11/01/2011
posted on 26/7/10 at 06:55 PM Reply With Quote
Well, pictures speak a thousand words as they say, all swear words...
I would say this is a very low mileage engine that hasn't run for, ooo 20 years?
Don't think I'll go any further than to dig that turbo engine out from its hidy place.
Just need the parts now to mate it up to the Landrover transmission.
My first V8just might become my first little coffee table
lotusmadandy
posted on 26/7/10 at 06:59 PM Reply With Quote
That doesn't look too promising atm mate.
It would be interesting to see further down the inards though.
posted on 26/7/10 at 07:00 PM Reply With Quote
Ooooh that looks nasty
Paul (Notts)
posted on 26/7/10 at 07:17 PM Reply With Quote
If the cylider bores are not rusty then it may well just need a good cleen.
if the bores are rusty then may be a little bit of a problem. Mine looked worse thatn that at first.
now makes 200hp with lots of tourque
posted on 26/7/10 at 07:22 PM Reply With Quote
How much did it cost though Paul?
I'm not really into rebuilding engines...
My T16 4 pot makes 210bhp....
Paul (Notts)
posted on 26/7/10 at 07:46 PM Reply With Quote
The only reason to put a rover V8 in a car is that you want a rover v8.
It will cost you the best part of £1000 to rebuild including carbs and ignition.
If you just want power then fit a modern engine..
Rover V8's do not make financial sense!!!
Paul
still love the sound of Mine
Irony
posted on 26/7/10 at 07:48 PM Reply With Quote
Oh lord. If the bores are okay then it might be a reasonable cost. If not, it'll probably cost you £1000 to fix it.
To late, what he said ^^^^^. At least we agree though Paul!
[Edited on 26/7/10 by Irony]
RAYLEE29
posted on 26/7/10 at 08:08 PM Reply With Quote
mm not nice hope you didnt pay much for it
rv8,s cost lots to rebuild but are lovely sounding once youve thrown away the carbs and exhausts and cam and spend loads on new bits I rebuilt one over 15 years ago and cost over a grand then its sat in a tr7 convertable in my one of my garages as it costs too much to run.
Ray
posted on 26/7/10 at 08:24 PM Reply With Quote
I'm not that fussed, it cost me £85 including a complete Landy trans.
posted on 26/7/10 at 08:29 PM Reply With Quote
Just been out there again, turning the front crank pulley which I suspects turns the crank theres no movement from the rockers and valve gear, that concludes the cam is not turning and the whole thing is f*cked!
robinj66
posted on 26/7/10 at 08:59 PM Reply With Quote
It might be that the timing chain has snapped or the teeth stripped form the standard cog (nylon teeth!).
Even so it might not cost a fortune to rebuild - just depends on how much power you want/need. Mains, big ends & cam bearings can be found pretty cheaply on Ebay - a standard RV8 cam costs about £60 and you can pick up an inlet manifold and SU carbs on Ebay for £15 - £20.
Get the heads off and have a proper look
[Edited on 26/7/10 by robinj66]
posted on 26/7/10 at 09:10 PM Reply With Quote
They have steel chain and sprockets AFAIK? Are you confusing it with the old Essex engine that used to regularly strip their fibre timing gear?
trextr7monkey
posted on 26/7/10 at 10:24 PM Reply With Quote
Hi Steve , just back from hols and catching up- there's a guy near us who runs a Morgan and a variety of Range riovers ish vehicle. He puts Toyota engines in to them but offered us a decent V8 engine a while back which he removed as head gasket was just starting to go, he was asking £150 ish which if it is still there could be a good option.
atb
Mike
ashg
posted on 26/7/10 at 11:05 PM Reply With Quote
Bin it not worth the bother. Have you contacted the seller?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Simon
posted on 26/7/10 at 11:49 PM Reply With Quote
Buy another one, but spend a bit more on it. Mine was £500 (but it came with all the running gear from the RR.
3.9 injected and I'm hoping to go for a mot later
Simon
Irony
posted on 27/7/10 at 07:29 AM Reply With Quote
I would suspect that there's all sorts of nastyness going on down in the depths. The only way to find out is to get the heads off. Assuming all the carb bolts come off easy its a 15 minute job to get a head off. Then you can have a look inside and see whats what.
I have a lot of Rover V8 parts knocking around here including a 3.5l crank which looks okay and some pistons that seem good. You can have them for beer tokens.
On another note if you decide to bin the whole RV8 then I might be interested in the transmission you have depending on condition and type. U2U if your interested.
mad4x4
posted on 27/7/10 at 07:54 AM Reply With Quote
NAH - Lower gear is FIber or Plastic - and it does strip!!! Mine striped becasue crap went through the shitty all pump and jamed the timing chain.....
Scot's do it better in Kilts.
posted on 27/7/10 at 07:58 AM Reply With Quote
nope - the cam gear definitely had nylon teeth - all steel as well as duplex gear wheels are avaialble.
<<  1    2  >>
