Author: Subject: LS V8 on ebay
liam.mccaffrey
posted on 21/8/10 at 09:12 PM Reply With Quote
LS V8 on ebay
NTDWM
[Edited on 21/8/10 by liam.mccaffrey]
Build Blog
Build Photo Album
steve m
posted on 21/8/10 at 09:14 PM Reply With Quote
Thanks Liam,
Thats locost !!
tomgregory2000
posted on 21/8/10 at 09:32 PM Reply With Quote
god thats cheap
if only i had the money
nnrouty
posted on 21/8/10 at 09:56 PM Reply With Quote
How much BHP would you get from that thing. 350-400BHP????
As long as its fast.... i don't care
Liam
posted on 21/8/10 at 10:47 PM Reply With Quote
With that 4x4 box on it it must be the truck version, known as the Vortec 5300 (no such thing as LS5). They dont make so much power and have iron blocks. Though that does look aluminiumy...
wiki...
Ah - there was an aluminium version of the Vortec 5300 used in a couple of models. 'Only' 280 - 300bhp. Still - wouldn't kick it out of bed. Probably cheaper lighter 300bhps to be had though.
bimbleuk
posted on 22/8/10 at 05:22 AM Reply With Quote
Very likely to about 325HP so not bad for a truck engine!. If it has an alloy block then it is probably an LH6. So not that different from my LS1 apart from the, smaller displacement, inlet manifold and maybe the cam (the heads may actually be better than mine). GM do mix n match there engines so you can find all sorts of parts on some of the production runs.
Mines an LS1 but has the LS6 inlet manifold and block which were improvements.
[Edited on 22-8-10 by bimbleuk]
