steve m
posted on 13/9/10 at 08:24 PM |
PIR light not working ??
Ive bought one of these lights, and have fitted it, despite no instructions !!
not exactley difficult!
Problem is, it dont bl**dy work
I can switch it on and off a few times on the inside switch, and it does come on, after about 4-5 flicks, but the light stays on permantley, not what
i intended
Anyone, got the sayings that should go with it ?
http://www.toolstation.com/shop/Lighting/Exterior+Lighting/60W+PIR+Half+Lantern+Black/d220/sd2663/p37604
mangogrooveworkshop
posted on 13/9/10 at 08:29 PM |
1st need to set the level of light for it to work.
second setting is for duration
quinnj3
posted on 13/9/10 at 08:38 PM |
This is an easy one to answer. Most new PIR lights have a function that if you turn them off-on-off-on they will stay on permantly. If its not
coming on at night try turning up the light sensitivity.
If that still is not working, take it back for a replacement.
my aim is to build my own locost wether it takes me a week or 10 years to get started, i'm sure i will sometime
steve m
posted on 13/9/10 at 08:44 PM |
It does not have ANY adjusments, unlike the old sensor lights that had duration, sensitivity ect
karlak
posted on 13/9/10 at 09:01 PM |
Are you sure - I bought one recently and the adjusters were very well hidden behind a flap, it looked like part of the sensor but lifted up to reveal
three adjusters. Post a piccie maybe someone has a similar one.
I reckon it would very unusal not to have some control over light and time settings..
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
YQUSTA
posted on 13/9/10 at 09:10 PM |
As said you are missing where the adjusters are find the little buggers
It must have them
"10-12 metre sensitivity range, 120 detection range. Time on 3 minutes +/- 20 secs"
"If in doubt flat out"
Colin McRae
MakeEverything
posted on 13/9/10 at 09:52 PM |
I hope you realise how that reads..... ?
Kindest Regards,
Richard.
matt_claydon
posted on 14/9/10 at 07:18 AM |
It must have them
I'd say the above text means it's not adjustable. Those ranges aren't very big and look far more like tolerances on fixed values.
steve m
posted on 14/9/10 at 10:57 AM |
I have just got a copy of the instructions
and "sensitivity and lux level are factory set and not adjustable"
still doesnt work though !!
