New Topic New Reply
Author: Subject: diff fitting?
-matt
posted on 7/10/10 at 09:53 AM Reply With Quote
diff fitting?
im trying to fit my diff, but seem to have a problem.
the MK brackets are 7" top and bottom.
but my diff is 7.5" at the top and 7" at the bottom.
is the diff supposed to be like this? or will i need a different diff?
cheers
-matt
posted on 7/10/10 at 10:06 AM Reply With Quote
just had a look in here: http://www.locostbuilders.co.uk/forum/3/viewthread.php?tid=143758
and it looks like ive got the 7.5" diff.
so looks like ill have to have a look out for a 7"
norm007
posted on 7/10/10 at 11:23 AM Reply With Quote
Where abouts are you?
Which ratio are you looking for?
I have a 3.62 if your interested?
Something about this, so very wrong.....I have to laugh out loud, I wish I didn`t like this!!!!!!!!!!!!!!
-matt
posted on 7/10/10 at 11:39 AM Reply With Quote
yes its a 3:62 (bolt on) im after.
im 217 miles from yorkshire, so its a bit far to go. but will keep you in mind if i can't find one soon.
midge
posted on 7/10/10 at 11:45 AM Reply With Quote
I had the same problem. I cut off the top left hand fixing on the chassis (all of the other fixing points match up), fitted the diff and made a new bracket for the remaining fixing. Also had to grind a bit off of the diff 'fins' to get it in.
hth Steve
dilley
posted on 7/10/10 at 12:33 PM Reply With Quote
I'm from Suffolk but traveling to yorkshire tomorrow if that helps?
INDY BIRD
posted on 8/10/10 at 05:00 PM Reply With Quote
i also have a reconditioned 7" 362 diff if needed like new,
based in essex if any help???
-matt
posted on 8/10/10 at 06:03 PM Reply With Quote
cheers lads for the offers, but ive gone for this, seems as its a LSD
3:62 LSD
New Topic New Reply
