sergebelg
posted on 25/10/10 at 10:25 AM |
VDO Speedo, black, digital, 80mm
My speedo is nearly dead : weird readings due to dampness... cupboard trick doesn't work anymore, so I think it's close to the
"fubar" level...
If a member has a spare speedo due to an upgrade... Mileage is not important as long as it's working and with the mph/kmh conversion..
Specs : 0-140 mph, 80mm, black
Thank you
Agriv8
posted on 25/10/10 at 10:37 AM |
have you checked magnets and pickups ( mine used to half read over a certain speed ) upgraded the pickup sessor to a VDO one happy ever since.
regards
Agriv8
sergebelg
posted on 25/10/10 at 12:05 PM |
The speedo gives a good speed reading (needle). The problem comes from the digital display : it flinkers, comes and goes, becomes blank, comes back
for a while...
Dusty
posted on 25/10/10 at 02:25 PM |
Interesting. My 80 mm VDO speedo runs off the Granada type 9 inductive sender and has been fine for four years. Last four months it reads fine for
about the first 15 minutes of a trip and then reads about two thirds speed for as long as the drive lasts. I do usually see some condensation on the
inside of the glass for the first 30 minutes of a drive but this is so for all the VDO gauges.
Common problem?
