dilley
posted on 24/11/10 at 09:19 AM |
mounting pipercross backplate
I need to mount a pipercross backplate to my hayabusa throttle boddies. I have the existing airbox and this has some type of trumpets that connect to
the throttle bodies and are pushed into the air box. Is the best way to fit these trumpets into the base plate? I am slightly worried that it will be
a tight enough fit?
Any help/pics appreciated..
Dilley.
norm007
posted on 24/11/10 at 09:28 AM |
Thats exactly how I mounted my back plate to GSXR750 throttle bodies.
Not had any problems in 3000 x miles.
Something about this, so very wrong.....I have to laugh out loud, I wish I didn`t like this!!!!!!!!!!!!!!
probablyleon
posted on 24/11/10 at 01:44 PM |
I chopped out the section of the standard airbox that connects to the throttle bodies and bonded that to the pipercross baseplate (or what was left of
it after I'd cut out enough material to let the ram stacks through). I think it's fairly important to retain the mouldings on the bottom
of the airbox so the little holes on the top of the TBs are accounted for. I should point our that this was for a Blackbird engine, I wouldn't
imagine this makes any difference though.
noc231073
posted on 24/11/10 at 09:26 PM |
I removed the rubbers from the original air box and used the air box. As a template to cut the piper alloy plate the put the rubbers in the alloy
plate
noc231073
posted on 24/11/10 at 09:28 PM |
If you think there not tight enough you can bond them in
dilley
posted on 24/11/10 at 11:32 PM |
All sorted, 4 decent size O rings stiffened it up nicely.
