Nick DV
posted on 19/11/11 at 03:47 AM |
Hayabusa Sump Mod & Baffle Plate
I want to shorten my Hayabusa sump, albeit by a fairly small amount (25 mm 'ish), but at the same time would it be best to enlarge it to
increase the capacity, and what type of baffle plate would be best to use? There are a couple of types out there, ie flat plates, the type that
Extreme sell etc. I am running an accusump also.
Any thoughts or advice would be most welcome
Cheers, Nick
"The force will be with you, always!"
iiyama
posted on 19/11/11 at 08:31 AM |
Thoughts or advice? GET IT BLOODY FINISHED!!!!!!!!!!!!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
Nick DV
posted on 19/11/11 at 10:00 AM |
Why spoil a good thing?
Cheers, Nick
danny keenan
posted on 19/11/11 at 11:52 AM |
hi nick
if i was you id spend the extra money and fit a billet sump with swinging pickup
thanks danny
Nick DV
posted on 19/11/11 at 11:56 AM |
Hi Danny, Icould do but I would have to modify the chassis rail to do so on my car, and that would be a PITA!
Cheers, Nick
big_l
posted on 20/11/11 at 11:47 AM |
I Been told all sorts on hayabusa sumps I was led to believe that a dry sump was the only safe setup ??? What do you have on your race car Danny ??
Check out my blog mnrvortxhayabusa@blogspot.com
Nick DV
posted on 20/11/11 at 01:08 PM |
Don't believe everything you are told Dry sump is not the only safe way to go. (Actually, dry sumps have failed on these and other engines).
There are a few people that run these with turbo power and slicks that have had no problem, HOWEVER they have kept the sump as per standard so that
you have full capacity. The only problem with this, is that it decreases the ground clearance.
Cheers, Nick
