jacko
| posted on 22/1/12 at 05:05 PM |
Aldi mini grinder ?
http://www.aldi.co.uk/uk/html/offers/special_buys3_23052.htm
Hi All
At Aldi on the Thursday 26 they have mini grinders / disc's etc for sale
Has anyone got one or used one are they worth the money ?
£17.99 and discs are £3.99 a set
Jacko
blakep82
| posted on 22/1/12 at 05:37 PM |
looks alright, and really at that price, if it doesn't last long, then fine! the best grinder i've ever had was the cheapest one i could
find in homebase, still going quite well, though the switch sometimes doesn't switch it on... always goes off though, so you know...
115mm is the smallest type that most of us tend to use though... and if i hadn't just bought 30 115mm cutting discs, i'd be tempted,
because i prefer that type of switch where you pull the handle in, rather than the ones with a switch on top, that doesn't automatically stop
when you let go.
had a loose wire in my extention cable once, switched the grinder on, nothing, stupidly let go of it with one hand, moved the extention, grinder span
into life, i couldn't hold it and nearly dropped it on my foot... and because it was still running, with was jumping about all over the place...
________________________
jacko
| posted on 22/1/12 at 05:47 PM |
Hi Blake
I have a 100mm grinder but i have just been given about 50- 125 mm part worn flap discs so when i saw this grinder i thought it will do the job
I HOPE
Graham
T66
| posted on 22/1/12 at 06:01 PM |
I bought the cordless version they did before Christmas, its actually very good for £12
blakep82
| posted on 22/1/12 at 07:04 PM |
yeah i'd say i'll do the job! looks good enough to me.
never seen a 100mm grinder before, you live and learn! lol
spiderman
| posted on 22/1/12 at 07:11 PM |
115mm discs will fit a 125 capacity disc grinder as long as the centre bore is the same size.
Spider
silverback
| posted on 22/1/12 at 07:47 PM |
At even that cheap price you really can't go wrong. I bought I think must have been the cheapest around at £7.99, and believe it or not it
lasted me over 2 years. I have now just bouht another one for £16 so I ope this lasts as long as my last.
I do quite a lot of grinding cutting sanding and polishing with these small 115mm grinders, so they do get a little bit of stick.
NigeEss
| posted on 22/1/12 at 08:29 PM |
I've one from last time they were in. works fine but the body is very bulky. Even
with fairly large hands it's not the most comfortable whizzer to use.
| posted on 22/1/12 at 09:56 PM |
I've had the Aldi grinder about 3 years now and it is a good size with the rear handle, no problem as I like them for the added grip they give
me with a right shoulder problem which means I always use grinders two handed.
eta:- this is different to mine as it has a variable speed control which could come in handy for polishing, 2,800 minimum.
[Edited on 23/1/12 by Peteff]
v832b
| posted on 6/2/12 at 08:33 PM |
thanks fgor the post
