Author: Subject: Battery cut off switch
jacko
posted on 19/2/12 at 05:56 PM Reply With Quote
eBay - The UK's Online Marketplace
I have just seen this on Ebay
Jacko
designer
posted on 19/2/12 at 06:10 PM Reply With Quote
Don't forget it's a disconnector, not a switch.
HowardB
posted on 19/2/12 at 06:25 PM Reply With Quote
I recall seeing similar that had a small (3amp) fuse in parallel to keep the clock working, but would blow if the engine was cranked on it,......
nice idea though
Howard
jacko
posted on 19/2/12 at 06:37 PM Reply With Quote
O yes it is
First line on the advert
loggyboy
posted on 19/2/12 at 07:00 PM Reply With Quote
Used to be sold branded as a 'discarnect' IIRC, Dad had them on his cars back in the early 90s and used to discarnect them when he went on holiday or left them standing for a few weeks.
EDIT - still are too Universal Richbrook DISCARNECT Battery Isolator Cut-Off Switch + fuselink | eBay
[Edited on 19/2/12 by loggyboy]
sky12042
posted on 19/2/12 at 07:29 PM Reply With Quote
got one on my car and its really handy cause i have a slight drain that i cant find, so i disconnect the battery and it will fire up when needed.
make sure you put on negative, tried on the positive first and it caused problems.
Andy.
stevegough
posted on 30/6/12 at 05:33 PM Reply With Quote
Andy.
Why do you need to fit it to the neg side? I am about to fit one, but I was going to fit it on the +ve 'channel'.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
