woodster
posted on 24/10/12 at 09:19 PM |
Mx5 herald
NTDWM and could be a re post but I'll share any way
http://www.ebay.co.uk/itm/Triumph-Herald-fitted-with-supercharged-mx5-engine-/261116895421?pt=Automobiles_UK&hash=item3ccbc7a0bd
snapper
posted on 24/10/12 at 09:51 PM |
Now if that was in a Spitfire
I would change the back end, the traverse spring even the later ones are no where as good as the front end double wishbones
I eat to survive
I drink to forget
mookaloid
posted on 24/10/12 at 10:43 PM |
Now that is a cool car
cliftyhanger
posted on 25/10/12 at 07:23 AM |
Yep, drop a scooby LSD in (actually not quite as easy as it sounds, as I am finding out) and some cv jointed rear shafts/ lower wishbones and it could
be a hoot of a car. (not a lot wrong with the transverse spring TBH, think of it as an upper wishbone and a clever spring all in one) Good looking too
pewe
posted on 25/10/12 at 08:17 AM |
Alternatively graft an MX5 back end on c/w Torsen slippy diff and you have a winner.
Better not let SWMBO know I've put it on my watch list!
Cheers, Pewe10
dhutch
posted on 25/10/12 at 10:24 AM |
Nice.
posted on 25/10/12 at 12:41 PM |
It is fundamentally different to a double wishbone system since with a swing axle there is only an inboard UJ, and the wheel has to adopt the same
angle as the driveshaft. The "upright" is coupled to the spring via a shackle arrangement, specifically so that the spring can not
influence the angle of the wheel (which would otherwise cause the entire suspension to bind up). In all, it's an absolutely horrific design.
The later "swing spring" arrangement was the cheapest possible workaround to the rear suspension deficiencies which simply reduced the
rear roll stiffness, which lessened the propensity for the wheels to tuck under (though it was quite ingenious).
The later Rotoflex design as used on the GT6 etc, was much more like a conventional double wishbone system.
