Author: Subject: Will these wheels fit my MK Indy
yellowcab
posted on 11/2/13 at 08:30 PM Reply With Quote
Fronts: 6J x 13, ET24
Rears: 8J x 13, ET24
Can anyone forsee any problems with my running these wheels, considering the 'standard' would be ET35
Please let me know if someone has tried before and succeeded/ failed.
Thanks in advance, Olz.
yellowcab
posted on 11/2/13 at 08:31 PM Reply With Quote
Just to clarify - I mean about the offset... as they'd stick out a further 11mm to my current wheels
Not so much the size of the wheels being 13s - I know i'd have to replace the rear caliper spring...
austin man
posted on 11/2/13 at 08:42 PM Reply With Quote
mat have to fit larger rear wings and nodify the front wing stays sorr cant be of more help
yellowcab
posted on 11/2/13 at 08:43 PM Reply With Quote
I presume ET40 would have been better... at least that way I could add spacers to bring them out a little...
ReMan
posted on 11/2/13 at 08:46 PM Reply With Quote
Err
They'll stick out 11 mm more than you current wheels?
Possibly more....
http://www.youtube.com/watch?v=nqqZ28m8uCo
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
posted on 11/2/13 at 08:50 PM Reply With Quote
I take it they're the correct PCD 4 x 108?
Phil
chris mason
posted on 11/2/13 at 08:56 PM Reply With Quote
Fronts won't cause you any problems, maybe a slight modification too the cycle wings and brackets and that should be ok, But the rear, assuming your currently on 7" rims with et38, then the 8x13 et 24, will stick out further by approx 23-24mm
INDY BIRD
posted on 11/2/13 at 08:59 PM Reply With Quote
Here you go this will help calc for you.
Link
http://www.willtheyfit.com/index.php?width=245&aspect=50&diameter=16&wheelwidth=7&offset=25&width2=235&aspect2=35&diameter 2=19&wheelwidth2=9.5&offset2
Ps it helped me sort out my wheel combo etc,
Sean
yellowcab
posted on 11/2/13 at 09:25 PM Reply With Quote
Thanks for the replies, yes they are 4x108 PCD...
The're Caterham R500 Superlight wheels...
Using the calculator above (cheers chap) they indeed will stick out another 24mm...
INDY BIRD
posted on 11/2/13 at 09:31 PM Reply With Quote
Just get a pair of the bigger rear arches job done?
You need big wheels
Mine are 9.5 inch rears love that look and run the r500 alloys too As my 2nd set wheels
yellowcab
posted on 11/2/13 at 09:35 PM Reply With Quote
Wouldn't want any adverse affects to the offset that was all.... I remember a while back on previous cars, having the lower offset can cause tram lining etc
Going now to search for pics of your Indy with the wheels on
INDY BIRD
posted on 11/2/13 at 09:51 PM Reply With Quote
Think you will find its what Danny uses on his mk race car with the wider arch,
Ask him I'm sure he can help on this,
But uses I think 7" fronts not the 6"
I use the wheels and don't suffer with tram lining as only have a 185 the on the front,
Sean
yellowcab
posted on 11/2/13 at 09:54 PM Reply With Quote
Cheers Sean, appreciate your help and experiences...
I will go ahead and buy them, can always sell them on if need be, but I doubt i will.
theduck
posted on 11/2/13 at 10:01 PM Reply With Quote
Will look awesome. Wanted some for mine but too expensive for my budget build.
