Author: Subject: Headlight Wiring
johnny chimpo
posted on 9/4/13 at 07:27 PM Reply With Quote
Headlight Wiring
Hi all, can anyone advise on what coloured wire is which when it comes to headlight wiring, ive binned my old 7" lights in favour of some dominators, but im trying to work out what colours do what.
The 4 wires i have in the car loom are.....
Black
Blue with red chaser
Blue with white chaser
Red with black chaser.
Just trying to figure out which is sidelights, dipped beam and main beam.
Cheers all...
Dunbikin
posted on 9/4/13 at 07:34 PM Reply With Quote
If you have got a multimeter, the easiest way to find out would be to check all wires for continuity to earth (probably be the black one) then turn the sidelight switch on and see what wire has 12v, then dipped beam switch, then main beam switch. Hope that makes sense.
Ron said it would cost 250 quid. My wife thinks it did.
johnny chimpo
posted on 9/4/13 at 07:44 PM Reply With Quote
Yeah makes perfect sense, cheers!
Only problem is my battery is goosed and lm waiting on a new one arriving. :-(
Dunbikin
posted on 9/4/13 at 08:15 PM Reply With Quote
Bugger !!!
Can you just check for continuity between the earth wire and the other 3 as you switch the switches.
SPYDER
posted on 9/4/13 at 08:18 PM Reply With Quote
Blue Red...LOW BEAM
Blue White..HIGH BEAM
Black... COMMON EARTH
The remaining Red Black probably SIDE LIGHT
Krismc
posted on 12/4/13 at 06:56 PM Reply With Quote
Red to red
Black to black
Blew to bits!!!
johnny chimpo
posted on 12/4/13 at 08:52 PM Reply With Quote
Originally posted by Krismc
Red to red
Black to black
Blew to bits!!!
This say is so true in so many instances, that's what I. Trying to avoid tho haha.
