Gear Monkey
posted on 6/5/14 at 10:24 PM |
Mix and match diff/stub shafts/drive shafts
Hello,
I'm building a BEC with a freelander Diff and intending to use mx5 uprights. The dilemma here is getting everything to fit. Now the mx5 drive
shafts like a sierra have a bolt on stub shaft and I believe (I'm sure I heard this somewhere) that sierra shafts will fit a freelander
diff???
Now if this is correct would be possible to fit sierra stubs to mx5 shafts allowing me to fit them to a freelander diff??
Chances are this is a (very) long shot but you never know!
Thanks in advance
Paul
adithorp
posted on 6/5/14 at 10:57 PM |
Sounds like you've got things a bit mixed up.
There are two types of Sierra shaft; Either push-in and bolt-on CV joints (in various sizes). Sierra bolt on joints are a 6 bolt "lobro"
pattern in 2 sizes
Freelanders use push in joints.
MX5s use bolt-on shafts in 2 patterns (though there are a very few push in ones).
Now if you strip and remove the inner CV joints from Sierra and Freelander PUSH-IN shafts, then the splines match. You can fit the Freelander inner CV
joint to the Sierra shaft, so you make hybrid push-in shafts (Freelander inner and Sierra outer). AFAIK the same doesn't apply to an other combo
using the bolt on shafts.
One problem with the hybrid described, the Freelander is a floating joint and the Seirra is sprung, so causes the Freelander CV bearings to bottom
out. There are ways around that though.
Sorry if that sounds complicated... but it is.
[Edited on 6/5/14 by adithorp]
http://jpsc.org.uk/forum/
Gear Monkey
posted on 7/5/14 at 06:57 AM |
Thanks for the info
[img][/img]
My mx5 shafts are the push in type with bolt on stubs. If it were possible to find / manufacture a stub which would push into the freelander diff that
would be perfect.
If i recall the cv joints on the mx5 are of the sliding type. I wonder if the freelander inner would fit with the mx5 outer? I'll need to get
both and start stripping them I guess.
[Edited on 7/5/14 by Gear Monkey]
Gear Monkey
posted on 7/5/14 at 07:33 AM |
Could this work as an interface between freelander shafts and mx5 hubs???
http://www.demon-tweeks.co.uk/motorsport/cv-joints-accessories/gkn-cv-joints
Paul
minitici
posted on 7/5/14 at 09:21 AM |
Ford Fiesta/Escort outer CV joints use 22 spline ended drive shafts which are the same as the ones used on the MX5 outer CV joints.
minitici
posted on 7/5/14 at 09:22 AM |
Paul
No.
