Monty2556
posted on 2/12/15 at 08:19 PM |
Rocker box breathing problem
I've got a 1600 xflow which pumps smoke out if the oil filler on the rocker box. I'm resigned to a rebore but I want to try one last
thing. I've been told by a mechanic to discard the PCV, take a pipe direct from where the PCV used to be to a catch tank and vent the other side
of the catch tank to atmosphere. Done all that - makes no difference. Now I've read on this forum to take a pipe from the old PCV outlet to the
rocker box and another pipe from the rocker box to the catch tank and vent the other side to atmosphere. So, three questions
1. Where on the rocker box do I put the input pipe?
2. Where on the rocker box do I site the outlet pipe?
3. Do I retain the existing oil filler cap which vents?
Many thanks
Adamirish
posted on 2/12/15 at 10:49 PM |
I am running a tuned 1700 Xflow. I run a breather straight from the old PCV location to the catch tank. Also run a breather straight from the oil
filler cap to the catch tank. I have no smoke issues at all.
Hope this helps.
MK Indy 1700 Xflow
plentywahalla
posted on 2/12/15 at 11:38 PM |
A properly set up catch tank should vent any crank case compression. So if you are still getting smoke venting out of the oil filler it means two
things. Either the crank case vent is blocked or the oil filler cap isn't sealing, or possibly both.
Are you getting anything in the catch tank at all? Also did you check the crank case vent was completely clear and did you use all new hose?
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
snapper
posted on 3/12/15 at 06:42 AM |
Remove PCV
Run pipe from block to side of rocker
Run pipe from back end of rocker to vented catch tank
Use unvented cap
If it still smokes rings
Running crankcase to rocker reduces the amount of oil in the catch tank on a heavy breathing engine but can increase the amount of water in the oil so
regular checks of the oil, look for white froth in the rocker cover, replace oil and filter at first sign of oil contamination
I eat to survive
I drink to forget
Monty2556
posted on 3/12/15 at 11:15 AM |
Thanks for all the advice.
The crankcase vent is clear and I'm using new hoses. I'm getting nothing in the catch tank. The oil filler cap appears to seal properly
but I've not checked that properly. Something else to try.
Many thanks
alfas
posted on 3/12/15 at 03:27 PM |
use a later cap, which has a hose connection, connect it to a catchtank.
conntact the block breather to the bottom of the catch tank.
under any circumstances, keep the original tin-can crankcase breather, but remove PCV valve
if you mount the catchtank higher than the block-breather connection any absorbed oil will get returned into crankcase
here a good overview, incl. pics
http://www.pistonheads.com/gassing/topic.asp?h=0&t=1534448&r=31856970&hm=192017&mid=192017#31856970
by the way: i never had any uprated x/flow which didnt smoke....even freshly bored engines!!!
[Edited on 3/12/15 by alfas]
