Danozeman
| posted on 21/3/05 at 06:43 PM |
compressor
This thursday in ALDI. 60 quid 25 litre compressor with spray gun etc..
Dan
bob
| posted on 21/3/05 at 06:58 PM |
Compressor and Accessories
each £ 59.99
One-cylinder air compressor, complete with sixpiece accessory set. Easy to use, it features a directly coupled motor and built-in starter, relief
pressure reducer, air intake filter and pressure switch, regulator gauge, self-stop quick coupling, drain valve and safety valve. The accessory kit
comprises tyre pressure gauge, blow-out gun, air hose and three-piece adaptor set.
230 volt
Speed 2850/min-1
Operating pressure 8 bar
Air intake capacity 210 litres per min
Air output at 0 bar = 140 litres per min.
[Edited on 21/3/05 by bob]
Ben_Copeland
| posted on 21/3/05 at 08:02 PM |
Didn;t quite catch that bob, say it again
Ok, you deleted them
[Edited on 21/3/05 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
bob
| posted on 21/3/05 at 09:19 PM |
Yeah sorry ben it kinda went pair shaped
Anyway i might well treat myself to one of thiose compressors,i'll go and have a look thursday.
Danozeman
| posted on 21/3/05 at 09:45 PM |
Thanks Bob. They look good. Shame it aint big enough to run an air wrench.
Dan
greggors84
| posted on 21/3/05 at 09:53 PM |
Does 140l/m convert to 5cfm? There are some 1/2" impact wrenches from machine mart that only need 4cfm, so may work. Or do you think the size of
the tank would be a problem?
Chris
The Magnificent 7!
theconrodkid
| posted on 21/3/05 at 10:20 PM |
http://www.lidl.co.uk/gb/index.nsf/pages/c.o.oow.20050328.p.Bicycle_Solar_Computer
who cares who wins
pass the pork pies
| posted on 21/3/05 at 10:32 PM |
I've got one of those on my pushbike, it doesn't update quick enough to use on a car. It jumps straight from 2 to 8mph then up to 18mph.
You have to keep an even speed to get a reading out of it so you wouldn't have a clue till you levelled off on the pedal.
| posted on 21/3/05 at 10:48 PM |
i have a similar small compressor. Im gonna buy an air receiver rather than upgrade it, and just let it fill it at will. even 1cfm will fill it
eventually! (4 hours actually... )
colibriman
| posted on 21/3/05 at 11:31 PM |
I've got a 1.5 hp 25 litre compressor and its not much good to run air tools like drills/grinders etc...a much bigger tank/air receiver would be
better.
need a bike engine? - www.colibriman.com
SVA ready Mk Indyblade possibly for sale.....if the offers good...!
Danozeman
| posted on 22/3/05 at 03:20 PM |
Will the pump keep up with the air loss from the tanks though?
Dan
colibriman
| posted on 22/3/05 at 03:33 PM |
NO.....its just not up to drilling and grinding at all... I keep having to stop - only after a minute or two at most......so I always go back to
electric tools..
I want/need a bigger compressor/receiver tank but am tight for space
screwfix have an upright 1.5hp/50 litre one for £79.99 which would be a bit better, but I stilll don't think it would be enough.
there was a new 3hp/100 litre upright one on ebay last week, went for £230 though
HTH
Colin
| posted on 23/3/05 at 11:16 AM |
1.5 hp will run impact wrenches and is just about good enough for a small nozzle spray gun.
the big air users are die grinders, cut off tools and air saws I have two 1.5 hp compressors that I couple together even then I don't have
enough cfm for my cut off tool.
[Edited on 23/3/05 by britishtrident]
