Author: Subject: dta ecu - cheap!
ned
posted on 14/9/05 at 09:30 AM Reply With Quote
dta ecu - cheap!
well i think it is, compared to cost new, with a rover (k-series maybe) harness.
ntdwm:
http://cgi.ebay.co.uk/DTA-E48-programable-ECU-and-harness_W0QQitemZ7999383967QQcategoryZ72205QQrdZ1QQcmdZViewItem
beware, I've got yellow skin
zilspeed
posted on 14/9/05 at 02:02 PM Reply With Quote
I can't ebay from here - how much is it ?
ned
posted on 14/9/05 at 02:04 PM Reply With Quote
£300 inc loom:
DTA E48 ECU, wiring harness, software, wiring diagrams and manuals
This ECU was checked and updated to latest spec in May this year by DTA
Model 4/FV/1/5
Version 1.2
F.Ware 34.0
It uses throttle position, coolant temp, O2, crank position, inlet air temp inputs and has outputs for injectors and ignition, it is about 10 years old and was checked and updated by DTA to latest spec and in very good condition, this ECU is not suitable for turbo engines though as it does not have MAP sensor inputs.
It is currently mapped for a 2 litre rally engine, but can be used on virtually any engine, the wiring harness is for a Rover 4 cylinder, 4 Bosch type injector, wasted spark ignition set up but can be used on most 4 cylinder normally aspirated engines
just to reiterate ntdwm, above is for zil's benefit
[Edited on 14/9/05 by ned]
zilspeed
posted on 14/9/05 at 02:48 PM Reply With Quote
Yes - tempting.
zzrpowerd-locost
posted on 17/9/05 at 08:36 PM Reply With Quote
went 4 311 quid
cheap aint the word
