Danozeman
| posted on 7/12/05 at 10:04 PM |
Interesting ARA racing.
This is ARA racings car.
ara dbr
Dan
skydivepaul
| posted on 7/12/05 at 10:18 PM |
That is a fantastic looking car......I want one
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
Aboardman
| posted on 7/12/05 at 10:47 PM |
i made enquiries about this and this was the reply
"Andrew,
many thanks for your interest in our DBR2 project.
We are sticking with the original concept and using a cosworth rear axle (from sierra, but Granada will also do). We use Raceleda Alloy front hubs
(but again granada/cortina will do). The rest of the rolling chassis is new, and fully rose jointed!
For engines we recommend a Jaguar lump, however almost anything will suit (Aston, rover V8, even got a chap with an M3 BMW!)
After the nine packages (£12700) You will also need to purchase prop shaft, exhaust and battery. Paint the car! thats about it!!
Have a good look through the package contents and you will see just how comprehensive they are!!!
We are limiting the number we sell. A deposit of 10% will book a place in the queue. A lead time is around 4 months at present"
however they then sent me an email saying not selling in kit form and will only do it turn key, at that point i was intrested.
Danozeman
| posted on 7/12/05 at 10:50 PM |
I heard they were only doing turn key. Although they still advertise kit packages.
They told me they had acquired 5 brand new aston engines to go in it too. I believe they were talking shite.
Dan
omega 24 v6
| posted on 7/12/05 at 11:07 PM |
Seem to remeber they popped up on ebay a while before they got a mention on here and then proceed to hack folk off with deliveries etc etc.
Chippy
| posted on 8/12/05 at 01:09 AM |
Whats the point of buying just a body thats had a 3k spray job, by the time you had it secured to a chassis etc. you would need a complete spray job
all over again. Daft I call it. IMHO Ray
Aboardman
| posted on 12/12/05 at 06:11 PM |
just had a email they are now selling in kit form.
Package A - Chassis £3,495.00
Component Quantity Notes Unit price
Space frame Chassis, fully bracketed 1 Painted choice of colours £1,850.00
Pedal box 1 Bias brake bar £310.00
Accelerator pedal 1 Painted £35.00
Accelerator cable 1 £15.00
Aluminium fuel tank 1 Baffled £280.00
leather fuel tank straps 2 £60.00
Fuel pipe 3mtrs Braided £35.00
Fuel fitting set 2 jubilee clips, cable ties, brackets £12.00
Body fitting bracket (rear) 1 Painted £140.00
Boot hinge bracket 1 Painted £160.00
Engine mounts 2 with Nylocs £110.00
Gearbox mounts 2 with Nylocs £45.00
Gearbox mounting plate 1 Painted £80.00
aluminium panels (pre cut, folded) 10 floor, footwells, bulkhead, £650.00
Exhaust mounting brackets 2 £12.00
Battery box 1 Aluminium £110.00
Rivet set 500 £14.00
chassis plate. 1 Chassis number provided n/a
Total if Purchased seperatly £3,918.00
Package B - Suspension £2,495.00
Pair front lower wishbones 2 Painted choice of colours £300.00
Pair front upper wishbones 2 Painted choice of colours £260.00
Rear De Dion 1 Painted choice of colours £400.00
Watts Linkage 1 Painted choice of colours £110.00
Watts Linkage bearing kit 1 Bearing, plates, nyloc £40.00
Pair Linkage arms 2 Painted choice of colours £60.00
4 x Trailing arms 4 Painted choice of colours £120.00
Adjustable shock absorbers 4 £290.00
Coil over springs 4 Choice of lbs £110.00
pair lower ball joints 2 £40.00
Pair upper ball joints 2 £26.00
20 x Rose Joints 20 £270.00
Nut/Bolt/washer package 28 all suspension, shocks etc £60.00
Modified steering rack 1 £380.00
Track rod ends 2 £38.00
Track rod end extensions 2 £26.00
Rack mounting kit 1 Aluminium bridges, nylocs £35.00
Modified steering column (exchange) 1 Ford Sierra exchange unit £140.00
Column mounting set 1 Rose joint, extensions, joints £28.00
modified half shafts (exchange) 2 exchange policy £300.00
Total if Purchased seperatly £3,033.00
Package C - Body £3,950.00
Complete Bodyshell 1 Gel coated n/a
Bonnet 1 Gel coated n/a
Boot 1 Gel coated n/a
Doors 2 Gel coated n/a
Headlamp bowls 2 Gel coated £160.00
Side louvres 3 Gel coated £80.00
Transmission tunnel 1 Gel coated £180.00
Grill 1 Chromed £160.00
Bonnet/boot hinges 4 Chromed £110.00
Screen 1 Poly £105.00
Sidescreens 2 Poly £85.00
Headlamp covers 2 Poly £240.00
Screen fitting strip 1 Aluminium £40.00
Sidescreen fitting strips 2 Aluminium £45.00
Screen/light fitting set 1 Screws/washers/rivets £16.00
Total if Purchased seperatly £1,221.00
Package D - Brakes £445.00
Copper brake pipes 5 Made to measure, with ends £110.00
Flexible brake hoses (front) 2 £45.00
Flexible brake hoses (rear) 2 £55.00
Pair brake master cylinders 2 £80.00
Handbrake 1 Stainless steel £240.00
Handbrake cable 3 £25.00
Handbrake mounting set 1 £15.00
Brake pipe fitting kit 1 p' clips, rivets £10.00
Fluid reservoir 1 clear £35.00
Reservoir fitting kit 1 bracket, 2 x hoses, Jubilee clips x 4 £20.00
Total if Purchased seperatly £635.00
Package E -Electrics £795.00
Complete colour coded wiring loom 1 ready to fit £290.00
Loom fitting instructions 1 colour coded n/a
Loom fitting kit 1 Cable ties, 'p' clips £22.00
Electric fuel pump 1 Pacet, with fitting kit £120.00
Pair front headlamps 2 Lucas style 7" £120.00
Pair front headlamp mounting bowls 2 £60.00
Pair front indicators 2 Lucas style £55.00
Pair Side indicators 2 £55.00
Pair rear indicators 2 Chrome rimmed £55.00
Pair rear stop lamps 2 Chrome rimmed £55.00
Rear fog light 1 £45.00
Rear number plate light 1 chrome £40.00
Positive battery cable 1 £12.00
Negative battery cable 1 £12.00
Horn 1 chrome Lucas style £28.00
Total if Purchased seperatly £969.00
Package F - Dash £795.00
Dashboard 1 Aluminium (various options available) £120.00
Speedo 1 Electric £190.00
Rev Counter 1 Electric £190.00
Fuel gauge 1 Various colours available £55.00
Oil gauge 1 Various colours available £55.00
Temperature gauge 1 Various colours available £55.00
Volt gauge 1 Various colours available £55.00
Speedo sensor 1 Various colours available £45.00
Fuel tank sensor 1 £45.00
Ignition 1 Including keys £40.00
Starter button 1 Chrome £35.00
Led warning light unit 1 £40.00
Fog light switch 1 Chrome £8.00
Fog warning light 1 £6.00
Indicator switch 1 £32.00
Headlamp switch 1 £32.00
Horn button 1 £14.00
Dash plaque 1 Indicating car number, date etc £60.00
Hazard warning switch 1 Authentic £60.00
Dash fitting kit 1 £40.00
relay unit 4 £44.00
Package G - Cooling £895.00
Radiator 1 Aluminium £380.00
Radiator fitting set 1 £22.00
Header tank 1 Aluminium £180.00
Header tank fitting set 1 £12.00
Header tank cap 1 £35.00
Radiator fan 1 Kenlow £130.00
Thermostat switch 1 Aluminium £48.00
Upper hoses 2 £50.00
Lower hoses 2 £50.00
Lower hose T piece 1 £55.00
Header tank hoses 2 £35.00
Jubilee clips 12 various sizes £36.00
Coolant fluid 1litre £11.00
Total if Purchased seperatly £1,044.00
Package H - Interior £1,745.00
Interior panel set 10 Aluminium £190.00
Authentic wood rim steering wheel 1 Moto lita £400.00
Boss 1 SVA £60.00
Wheel fitting kit 1 £20.00
Pair leather bucket seats 2 Choice of colours £580.00
Leather headrest 1 Choice of colours £80.00
Leather gear gaiter 1 Choice of colours £38.00
Leather handbrake gaiter 1 Choice of colours £38.00
Gearlever 1 Chrome £48.00
Aluminium gearknob 1 £38.00
Pair four point harnesses 2 Choice of colours £140.00
Harness fitting kit 1 £6.00
Door frames 2 Or choice of door skins £140.00
Kick plates 2 Stainless steel £44.00
Rear view mirror 1 Chrome £28.00
Rear view mirror mount 1 Chrome £9.00
Boot panel set 6 Aluminium £140.00
Boot prop 1 £16.00
Total if Purchased seperatly £2,015.00
Package I - Brightwork £495.00
Bonnet handles 2 Chrome £88.00
Boot handles 2 Chrome £88.00
Aluminium side vents 2 Machined £160.00
Side vent fitting set 1 £4.00
Pair wing mirrors 2 Chrome £62.00
Wing mirror fitting kit 1 £4.00
Fuel cap (Aston style) 1 Aluminium £69.00
Air vent mesh 2 Aluminium £18.00
Side screen clips 2 Aluminium £9.50
Exhaust side vent mesh 4 Aluminium £28.00
Bonnet badge 1 Aluminium £40.00
Total if Purchased seperatly £570.50
Package J - SVA £99.00
Build folder 1 For receipts, notes etc £22.00
SVA manual 1 £24.99
SVA caps 1 £8.00
Rubber finishing strips 8 £60.00
rear reflectors 2 £8.00
Pedal rubber gripping 3 £6.00
Camber/caster set up instructions 1 free
Total if Purchased seperatly £128.99
Price summary
Package A £3,495.00
Package B £2,495.00
Package C £3,950.00
Package D £445.00
Package E £945.00
Package F £795.00
Package G £895.00
Package H £1,745.00
Package I £495.00
Package J £99.00
TOTAL £15,359.00
Price to purchase packages A + B + C £9,000.00 (discount of £940!!!)
Price to purchase all packages £13,950.00 (discount of £1,409!!!)
