Author: Subject: Alloy bell housing
mookaloid
posted on 18/2/06 at 10:35 PM Reply With Quote
Alloy bell housing
someone was after one of these I think
http://cgi.ebay.co.uk/Ford-RS-2000-Genuine-Alloy-Bell-Housing_W0QQitemZ8039964103QQcategoryZ27377QQrdZ1QQcmdZViewItem
or
http://cgi.ebay.co.uk/ford-escort-rs-2000-alloy-bellhousing-rally-car-grp4_W0QQitemZ4613860242QQcategoryZ21654QQrdZ1QQcmdZViewItem
[Edited on 18/2/06 by mookaloid]
andylancaster3000
posted on 19/2/06 at 10:23 AM Reply With Quote
Do they all have the starter locations on both sides? It would be nice to use one of these but I doubt it would fit in our chassis.
mookaloid
posted on 19/2/06 at 10:57 AM Reply With Quote
the clutch fork sits in the other side
Deckman001
posted on 19/2/06 at 11:23 AM Reply With Quote
There is a starter position on each side, and yes you can fit them into a book chassis You will need to make up a bracket to hold the clutch cable adjuster, and you will also need to modify a std fork if using it, the rs fork will work as std as it's a narrow jobbie
Hope this helps
Jason
