dirty130
posted on 28/8/06 at 10:25 PM |
CVH engine management unit
I have a 1.6 pinto and a 1.8 CHV EMU and im thinking about combining them. I have worked out i should only need 6 pins off the EMU as the standard EMU
that should be on the 1.6 pinto has 6 pins. but i need to know if the crank sensor, air flow sensor are actualy needed? or can i just connect them
together?
It will fit wheres me hammer?
posted on 29/8/06 at 09:59 AM |
can't answer the question I'm afraid, but I do think you may be making things harder than you need to. Would it not be beter to use the
standard 1.6 Pinto electronic ignition set-up consisting of ignition amplifier, coil and inductive discharge dizzy?
Designed to work, proven to work and so simple to install.
Just my take on it
dirty130
posted on 29/8/06 at 10:11 AM |
If i had the unit it would be easyer but i cannot get hold of 1
