TangoMan
| posted on 8/12/06 at 10:43 PM |
Vauxhall to Type 9 Conversion
Might be of use to someone for a WINTER PROJECT!!
Click Me
Summer's here!!!!
Chippy
| posted on 9/12/06 at 12:07 AM |
States four speed type 9 box, Hmmm! it's definately a type nine, so wheres the fifth gear gone!!!  Ray
RichieW
| posted on 9/12/06 at 12:09 AM |
Beat me to it there chippy
oliwb
| posted on 9/12/06 at 09:45 AM |
Doesn't really matter though does it?? seen as:
1 - ford used the same bolt pattern (certainly on the engines so I assume on the boxes as well)
2 - the type 9 is actually another box (can't remember the designation) with an overdrive for 5th
3 - Depending on your diff you may never use 5th anyway!
Oli.
Danozeman
| posted on 9/12/06 at 11:00 AM |
That gear lever doesnt look like a type 9 one..
Dan
goodall
| posted on 9/12/06 at 02:42 PM |
but vauxhall used a torque tube so you would be changeing the whole drive charistics of the car, unless you weren't planning on putting this
into a vauxhall car but were going to use a GM engine in a locost now thats a different storey
[Edited on 9/12/06 by goodall]
| posted on 9/12/06 at 02:48 PM |
Oli.
But depending on which 4 speed box it is, it could matter as the gear lever is further back on the Type9 then some of the 4 speeds.
D Beddows
| posted on 9/12/06 at 03:34 PM |
Don't see why people are getting their knickers in a twist with this one It's a Type E (according to Burtons identification system) 4
speed gearbox probably from an RS2000 Escort. Very similar ratios to a type 9 but with only 4 forward gears and a crappy screw in gearstick like the
older 4 speeds
procomp
| posted on 9/12/06 at 08:16 PM |
Hi it's the 4 speed box that is not a type 9 but an awful lot of people refer to as a type 9 usually found in 2ltr cortinas or some sierras.
The gear leaver looks like it could be a proper rose jointed quick shift item looking at the screw mount.
cheers matt
