Author: Subject: Cheap Gauges :Update
rayward
posted on 17/2/07 at 04:59 PM Reply With Quote
follow up to This Thread
my gauges have arrives from the USA,
total cost for 6 gauges, complete with senders £195 (got stung for £39 import duty!!)
gearbox sender cost $35 extra, but don't think its suitable for a type 9 so would work out a bit cheaper for anyone else.
probably not SVA friendly, as the edges aren't rounded, and stick out approx 10mm
gauges
gauges
gearbox sender
gearbox sender
[img][/img]
novacaine
posted on 17/2/07 at 05:41 PM Reply With Quote
Originally posted by rayward
gauges
gauges
you realy shouldnt rev your engine up to 8000 when its cold
ohh im sooo funny lol
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
bilbo
posted on 17/2/07 at 06:20 PM Reply With Quote
I have to say I'm quite interested in these (well, certainly the price). What sort of quality are they?
Also, how did the import duty work? Did they simply add it to the price, or did you have to make seperate arrangements?
Thanks,
Bill
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
rayward
posted on 17/2/07 at 06:24 PM Reply With Quote
well made, they do different, combinations (including a 4 in1 80mm gauge),as well as different background and needle colour combinations.
parcel force send you a letter detailing the import duty, you pay them then they deliver them
Ray
bilbo
posted on 17/2/07 at 06:35 PM Reply With Quote
Thanks for that, I'm sorely tempted now...better check the bank balance first though
tim windmill
posted on 18/2/07 at 10:20 AM Reply With Quote
they look good ray, is the car on the road yet? trying to find out when everyones is on the road so we can all meet up for a run out. we are putting ours on the road at the beginning of march,
rayward
posted on 18/2/07 at 02:11 PM Reply With Quote
yep on the road, trying to do each job one at a time, and get it finished so i don;t lose any "on the road" time
Ray
PeterW
posted on 20/2/07 at 03:33 PM Reply With Quote
Ray
What are you planning on using to drive the speedo...? I've seen something similar, and it needs a gearbox pulse generator and I've no idea where to start....
Peter
rayward
posted on 20/2/07 at 05:26 PM Reply With Quote
i'm going to use a reed switch or proximity sensor, and either pick up the abs castellations(sp?) on the hub, or stick magnets on the propshaft
Ray
PeterW
posted on 7/3/07 at 10:07 AM Reply With Quote
Ray
Got any further with the speedo drive for this...?? Looking at a similar set at the moment
CHeers
Pete
