davrus
| posted on 23/5/07 at 08:51 PM |
Aldi mig welder, is it any good
Not too clued up on welders, is the aldi on that they have on offer any good and worth getting.
Linky
I know a lot of you have already seen it but i am after some advise.
Dave
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
Keith Weiland
| posted on 23/5/07 at 09:05 PM |
Well its no gas so it will be a bit messier than a normal one, It doesn't say if it can be converted or not. I don't think its the kind of
thing you should skimp on but if your on a tight budget it would probably do the job and similar welders are quite a bit more elsewhere.
Mole
| posted on 23/5/07 at 09:53 PM |
It does not look like it can be converted as no gas has postive earth and those that can be changed have a facility to swap the terminals. It actually
resembles a SIP/Cosmo (although might not be) and they have poor wire feed by all accounts. I bought this one
http://www.lawson-his.co.uk/scripts/products.php?cat=MIG%20Welding%20Machines%20%3C%20200%20amp. Although its less powerful it is fine for 16 swg.
Mole
| posted on 23/5/07 at 09:55 PM |
The clamp set looks a decent deal though
wacomuk
| posted on 23/5/07 at 10:33 PM |
i have a gas less or MOG welder and its great only down side is the wire is expensive
http://www.insightbookingsolutions.co.uk
Taz Surfleet
| posted on 23/5/07 at 11:26 PM |
I have a clarke 150 & 90 gasless (no garage etc!!) used to think the 90 was ok till I used the 150 the quality and ease of welding is far
superior, only advise i can give is to use some anti-spatter spray ( from machine mart ) makes a hell of a difference and saves a lot of tidying up
afterwards. oh if any one wants a cheap clarke 90 gasless I know were theres a spare one !!
