Author: Subject: Which pinto clutch cable ?
ayoungman
posted on 5/6/07 at 07:51 AM Reply With Quote
What clutch cable have people used for a pinto in their avons? Plus, how have you run the cable to avoid the exhaust primarys.? Thanks fellas, now on the big push to get the thing running you see !
"just like that !"
gregs
posted on 5/6/07 at 08:12 AM Reply With Quote
Not sure about the Avon - if it uses a Ford type clutch cable then following might be useful: on RH 2B's the recommended is a Cosworth cable, is long enough that it reaches around the front of the headers before going down, under and back to the clutch - cable is the best part of 5ft long!
Avoneer
posted on 5/6/07 at 11:06 AM Reply With Quote
Standard Sierra Pinto one.
Mine went under the headers and was held down by a small bracket from one of the bolts from the bell housing.
www.mytigeravon.co.uk
Pat...
peterparsons
posted on 5/6/07 at 01:12 PM Reply With Quote
I used a 2ltr Capri Cluch Cable
andrew.carwithen
posted on 5/6/07 at 01:34 PM Reply With Quote
Loking at your photo archive. it looks like you have fitted the Sierra pedal box, so therefore, as Pat says, you would need a Sierra clutch cable.
However, if you ditched it and fitted floor mounted pedals, then you would need a clutch cable from say a Capri or Cortina as they had a nipple for the bellhousing end and an eye to attach to your clutch pedal.
Andy.
ayoungman
posted on 5/6/07 at 10:09 PM Reply With Quote
ok, thanks fellas. Looks like I go for a standard sierra jobbie. One step closer to the big day then
"just like that !"
