Browser
| posted on 15/7/07 at 07:10 PM |
Pressurised airbox on Ebay
Not mine,
pl
enum for turbo car with dump valve fitted.
Benzine
| posted on 15/7/07 at 07:35 PM |
Anyone know what mods would need to be done to the DCOEs to use this? ^__^
Browser
| posted on 15/7/07 at 08:53 PM |
AS far as i know carbs have to be designed to take the pressurisation associated with turbocharging. Lotus Used Dellortos on the Esprit Turbo, you can
read about it here, specifically this bit:
"This was the first time that these carburettors had been used on the pressurised side of the forced induction system, so they incorporated
pressure seals around the spindles to stop the pressurised petrol / air mix from escaping. The Lotus Esprit system remains unusual among turbocharged,
carburettor fed engines in blowing rather than sucking, through the carburettors"
So you could suck through the carbs but you are then pressurising a petrol/air mix, not the best idea (I wouldn't have thought) from a
safety/cool mixture point of view.
daviep
| posted on 15/7/07 at 10:29 PM |
The fact that the carbs are inside the airbox means you shouldn't have any problems with the carbs leaking air or fuel as the air pressure is
equal on the inside and outside of the carburator. In theory you shouldn't have to modify the carbs at all as this is exactly the same
circumstances as a naturally aspirated engine with the carb exposed to atmospheric pressure.
Thats my understanding anyway.
Davie
Fatboy Dave
| posted on 15/7/07 at 10:32 PM |
Indeed that is correct, but that's called a boost box, which the auction is not for. It's for an air box/plenum that bolts to the side of
a set of DCOEs, so you do need turbo spec carbs.
ISTR from the rather dim and forgotten corners of my beer, porn and petrol addled mind that all 'new' DCOEs have spindle seals that allow
them to be used with turbos? Could be mistaken though. I hate DCOEs.
Dave
Stop the planet, I want to get off
daviep
| posted on 15/7/07 at 10:35 PM |
The link to the lotus diagram differs in that the carbs are not enclosed in the airbox. This means air pressure inside the carb will be greater than
the pressure outside and will have the tendancy to blow fuel/air out the butterfly spindles.
EDIT:
Yep I type too slow! Didn't look properly, doesn't even look deep enough to house a set of carbs now that I've had a good look.
You must have to hook up the float bowls to the pressurised side of the system as well I would have thought?
I'm curoius now
Davie
[Edited on 15/7/07 by daviep]
Fatboy Dave
| posted on 15/7/07 at 10:37 PM |
I know, that's why I posted the above...?
Dave
