dirty130
posted on 27/12/07 at 03:06 PM |
16mm to 19mm reducer
hello, im just working on my cooling system and i need a 16mm to 19mm reduced to connect the water pump to the expansion tank. any ideas where i can
get 1 from? thanks
It will fit wheres me hammer?
posted on 27/12/07 at 03:15 PM |
i used copper for all mine. 16mm is a 15mm pipe with an olive compressed on, 19mm is not far off the outside of a 15mm solderring fitting. Its a bit
of a bodge but it gets the job done. Mine lasted many trackdays with a lot worse things done than that! Such as a 28mm fitting soldered inside a 35mm
pipe!
RazMan
posted on 27/12/07 at 03:17 PM |
As you only need a small decrease in size, how about wrapping some self-amalgamating tape arount the smaller spigot?
Raz
tks
posted on 27/12/07 at 03:18 PM |
if you get a small piece of stainless 16mm tube and a piece of 19mm x 1,5mm tube it should be easy to get it working..
Tks
Paul TigerB6
posted on 27/12/07 at 03:20 PM |
Merlin Motorsport do these...
19mm - 16mm reducer
or are you looking for a ali reducer??
[Edited on 27/12/07 by Paul TigerB6]
Paul TigerB6
posted on 27/12/07 at 04:23 PM |
Turn the above Merlin part upside down and it will be an increaser then!! "Samco" will of course be not so easy to read though!!!
bonzoronnie
posted on 27/12/07 at 05:11 PM |
quote: Originally posted by Dragon-Performance-Eu
Please excuse my ignorance but isnt going from 16 to 19 an increase in size when expressed as you did and not a reduction
Now a 19 to 16 is a reduction
Ronnie
posted on 27/12/07 at 06:19 PM |
Depends which way the water circulates?
dirty130
posted on 27/12/07 at 08:56 PM |
well its not like i could go to a motor spares and ask for an increaser. i might get funny looks.
Paul TigerB6
posted on 28/12/07 at 09:53 AM |
Oh i dunno - try it and see.........
"you might wish to try the internet sir"
