Author: Subject: 10BAR VDO oil pressure senders
carlknight1982
posted on 26/4/08 at 09:50 PM Reply With Quote
I can get hold of VDO 10BAR oil pressure senders thru work, open to sensible offers or swaps
Dave Bailey
posted on 26/4/08 at 11:10 PM Reply With Quote
Hi! Are these switches or for digital dash i.e transducers?
Do you know what thread they are?
thanks
Dave B
carlknight1982
posted on 27/4/08 at 08:26 AM Reply With Quote
they are not simple switches for running the lights,
this is what i have managed to find out 360-025 VDO Oil Pressure Sender 150psi / 10 Bar
10 Bar / 150 psi sender.
1/8 NPT thread. This twin terminal sender uses the second terminal for the oil pressure warning lamp which will light if pressure drops below 11.4 psi. Ground is via the engine block.
I know we use them to run a oil pressure gauge off one feed and the ECU shutdown protection off the other
Hope this helps, I also believe (dont quote me) that ETB use this sender
