Getting to the final stages of plumbing in my Zetec and not sure on one off take. It's at the rear of the fuel rail / inlet manifold, it
currently has a 90 degree elbow fitted which is as it came with the donor engine. It looks like it could be a breather but not sure. Can anyone tell
me if this should be connected to anything and if so what. Hopefully theres a photo with the elbow circled.
Colin
OK no photo, will try again.
Colin
Assuming the big circle it looks like the oil breather connector between the breather thingy on the block and the inlet manifold.
It is the oil breather and connects into a metal pipe which straddles the back of the head. The far side plugs into the crank case breather box
beneath the exhaust pipes. I have posted the picture in my picture files for you to see. If you want more info send a U2U.
Ian
