Good evening gents, Does anyone know where I can get a replacement scale for the above gauge?
I've just fired off an email to Dunlop themselves, just after some more suggestions.
I need to replace the damage in these pictures.
Cheers Dan.
[Edited on 11/12/08 by scutter]
Thats why mine live in a custom made box. Have you seen the price of a set these days?
adrian
These have been in general use by a club for the past 25years, haven't been touched for 5, you should have seen the dust when i brought them down
off the top of the cupboard
And yes, which i'm trying to fix these, there's no money for replacements.
ATB Dan.
Hi Dan I have the same tracking guages as those the scale is in good condition on mine if you get stuck you are very welcome to make a copy off mine
also that way it wont cost you anything
atb Trev
Trev, your a star. would it be too much trouble to scan it for me? next to a steel rule so i can scale the image would be ideal. If not it'll
be a good trip up sunny northampton
ATB Dan.
sorry to hijack the thread..
i have the same gauges and am missing the little rubber eye cup....
if anyone knows of any suppliers i would be grateful
Ours don't have one, just squint
ATB Dan.
ive got the same gauges,i rang dunlop and they said they had spares in stock,got the eye piece rubber and the white scale you read from,only a few
pence as well
Cheers John.
I have the same gauges and am missing the little rubber eye cup....
Without the rubber pad you can't catch the apprentice out with the black eye practical joke although it's still possible to use the gauges.
Hi Dan the scanned image is in my photo archive number 10001 what you could do with the remainder of the scale that you have is if you put both
tracking guages together look through the viewfinder and align the arrow perfectly that will then give you the zero position on your scale. Then you
could trap the scale under the bar where it should originally be fitted then your gauges will be calibrated and ready to use. Hope this is of some
help
regards Trev
Trev, Many Thanks.
ATB Dan.
Originally posted by theconrodkid
ive got the same gauges,i rang dunlop and they said they had spares in stock,got the eye piece rubber and the white scale you read from,only a few pence as well![]()
