i was hoping i could get somthing like this to put on my grinder that looks like item 2
http://cgi.ebay.co.uk/POLISHING-ADAPTER-FOR-DRILL-MOP-PIGS-TAIL_W0QQitemZ310110868223QQcmdZViewItemQQptZUK_BOI_Metalworking_Milling_Welding_Metalworki
ng_Supplies_ET?hash=item310110868223&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A15%7C39%3A1%7C240%3A1318
im looking on how to do this to my grinder
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270319947961&ssPageName=MERC_VI_RCRX_Pr12_PcY_BIN_Stores_IT&refitem=280296620448&
itemcount=12&refwidgetloc=active_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparm
s=algo%3DCRX%26its%3DS%252BI%252BSS%26itu%3DISS%252BUCI%252BSI%26otn%3D12
NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO
the grinder spins toooooo fast and will just burn the surface
ok ok ok ok ok gooooooooooooooood
i take it it is a no then i seen a grinder thats also a p[olisher on ebay item number 280296199604
I had a grinder with variable speed which I used on the lowest setting for polishing/ buffing paintwork with no problems
Ive used a simular item as in the OP to fitt a buffing mop to a bench grider for cleaning up brass. But i would agree that for polishing paint, unless
its a decent variable speed job, an angle grinder would be to fast.
Often though about using a orbital sander....
Daniel
Depends on what you plan to polish. No good for paintwork, but if you are polishing metal then it would be OK
John
A dual action sander is a good alternative. You can get them cheap from Aldi sometimes then buy a head like this for it.
SORRY I JUST WORKED OUT YOU ON ABOUT THE OTHERE TYPE OF GRINDE NOT THE TWIN WHEEL TYPE
IM LOOKING A A METAL POLISHER WITH MOPS AND SOAP FOR ALLOY AND STAINLESS.
[Edited on 24/12/08 by thunderace]
This is defo place for paintwork polishing saved me a fortune by not buying the wrong equipment
Detailing world dual action polisher
I'm sure that's all they are anyway
