My fuel rail has a 1/2" bore (12.7mm).
The question is what the heck should I tap it with?
3/8 NPTF is a 14.25mm hole, no problem, but I can't get hold of an NPTF tap... (got NPT, but no NPTF!)
3/8" BSPT is a 14.75mm hole, but with a major diameter of 16.66mm its getting a bit tight (2.5mm) on the wall thickness of my fuel rail.
Any ideas? This is one of the last jobs holding me up with my MS install
Weld in a bung and drill and tap an M10???
As above or weld a nut on top of the hole.
Depends what the fuel rail is made out of....
An easy option would buy some 1/2" round bar (some on Ebay for couple of quid), drill a 8mm hole through a slug of it, epoxy it into the end of
the fuel rail, epoxy some 8mm copper pipe through the middle of the slug, epoxy or solder an 8mm plumbing olive onto the end of the copper pipe to
stop the hose blowing off.
If you don't like epoxy you could always use some technoweld or similar to friction braze the slug in. And you could always tap the slug to take a hose barb if you don't like copper tube + olive solutions....
put it in the lathe and cut the thread. sorted
Should perhaps add that it is aluminium fuel rail extrusion, like this:
http://www.rossmachineracing.com/dash6.html
I could tap it AN but again, I cant get hold of a tap and it makes getting fittings more difficult.
I could just tap it UNF and seal the thread with an aluminium crush washer...
I'd go with the NPT David.
Paul G
If it is aluminium could you use a threaded insert. I can't remember the exact name for them but they have a course thread on the outside and a
proper thread on the inside.
edit to add: I think they are called a helicoil
[Edited on 8/1/09 by stuart_g]
Paul G
David, don't the AN fittings use UNF threads?
Yes Alan the AN fittings do use UNF threads....
A AN-6 for a 3/8" hose uses a 9/16"-18 (UNF) thread.
Originally posted by Alan B
Yes Alan the AN fittings do use UNF threads....![]()
I did mine M14 x1.5 as it's tap size is bang on 1/2", and then used a male-male adapter. I think clairetoo found a much easier/cheaper way to fit 8mm barbed tails to the end of the rail though...
